Any triumph spitfire experience?
Old Aug 31, 2014 | 09:23 AM
  #31
PTR300's Avatar
Originally Posted by cheshire_carper
Originally Posted by Daytona-Dave' timestamp='1409436334' post='23309011
Here's one for You Colin, couple of weeks should put it right
If you think you have the time for it. Let's do it
Go for it ! plenty of patina to go around ! although plenty of beer would probably help.....
Old Aug 31, 2014 | 09:31 AM
  #32
lower's Avatar
Originally Posted by GreenmanS2000
The sprint 16v engine, more specifically the had, was fundamentally flawed in that the head bolts were vertical so it could never be torqued properly. Hence all the head gasket issues.
That was its reputation, but it's main problem was the mix of materials in the engine. Specifically the block was iron and the head was aluminium which meant it was critical that the coolant was the correct mix. If it wasn't the cooling system would clog up with corrosion by products and the engine would overheat and blow its head gasket.
I had a Herald 13/60 convertible as my first car that I completely rebuilt after the chassis rusted through. The only bit I didn't rebuild was the diff. You can strip most of the car just with a 1/2" spanner and lots of plus gas and all of the engines, drivetrain and running gear is common between the spitfire, gt6, herald and vitesse.
The mk3 is my favourite Spit. It has the best mix of the older looks but with the 1296cc engine. The mk4's handling with the swing spring was better but I just don't like the look of the car as much. I'd agree with Gad in avoiding the 1500. It's just a stroked 1296 and is not an engine suited to a sports car.
Old Sep 3, 2014 | 04:44 AM
  #33
GreenmanS2000's Avatar
The 1500 Spitfire has the added disadvantage of "wax" jets in the carb which tend to get sticky when hot....It's an asthmatic lump - c75bhp if I recall, although c85 is possible with head work, a free flowing (Triumph Tune) exhaust and some decent carbs.
The overdrive is good fun - you can tell people you have a 7 speed gearbox (8 if you fiddle with it to allow O/S in first)
Old Sep 3, 2014 | 09:05 AM
  #34
cheshire_carper's Avatar
I may well end up with a 1500 as there's lots of them and should the plan fail, I'll just scrap it.
Old Sep 3, 2014 | 10:14 AM
  #35
PTR300's Avatar
Noooooh !! go for the 1300, earlier car, much better bet
Here you go , mark 3 1300 resto.
http://www.tssc.org.uk/tssc/classifi...ssified_ID=332
Model name Engine Year Number built
Triumph Spitfire 4 (Mark 1) 1147 cc inline 4 Oct 1962 – Dec 1964 45,753[1]
Triumph Spitfire 4 Mark 2 1147 cc inline 4 Dec 1964 – Jan 1967 37,409[1]
Triumph Spitfire Mark 3 1296 cc inline 4 Jan 1967– Dec 1970 65,320[1]
Triumph Spitfire Mark IV 1296 cc inline 4 Nov 1970 – Dec 1974 70,021[1]
Triumph Spitfire 1500 1493 cc inline 4 Dec 1974 – Aug 1980 95,829[1]
Pinky
Nov 2, 2012 07:20 PM
j8mie
Jan 31, 2011 02:27 AM
SPLNDID
Mar 16, 2007 09:22 AM
Napoleon Dynamite
May 30, 2005 02:59 PM
bigsley18
Jan 23, 2005 08:08 AM
