Lambda Sensors
Old Jan 28, 2010 | 11:36 AM
loftust's Avatar
Default Lambda Sensors
As part of my degree, I will be required to write about a measurement system...lambda sensors then came to mind.
How do they actually work? I'm talking about how it converts the exhaust gases into a voltage that can be used by the ECU...what is this process? What happens after the sensor, does it just go straight to the ECU, or is there something in the middle?
Old Jan 28, 2010 | 11:45 AM
MB's Avatar
MB
Member
Some good info here:
http://www.picoauto.com/applications/lambda-sensor.html
The voltage signal is sent directly to the ECU to be used on closed loop fuelling
It's actually an interesting topic.
Most modern cars now use 2 sensors for feedback, and some VW type cars use widebands as OEM fitment...
Old Jan 28, 2010 | 11:51 AM
Nick Graves's Avatar
Useful read
Old Jan 28, 2010 | 12:00 PM
loftust's Avatar
Thanks MB...that's really good stuff...interesting read about the contents of a lambda sensor...if you're a geek like me (and obviously Nick as well )
Does anyone know what happens to the voltage once it has reached the ECU? Does it undergo amplification before A-D conversion etc?
Old Jan 28, 2010 | 12:09 PM
MB's Avatar
MB
Member
I think the ECU just uses the raw signal and interprets it as an AFR.
Old Jan 28, 2010 | 12:18 PM
Dembo's Avatar
Interesting, but I didn't understand why the sensor "flip flops" from rich to lean. Does that mean that the exhaust mixture is changing, or that the exhaust mixture remains the same and the sensor just can't give a stable output?
Old Jan 28, 2010 | 12:23 PM
MB's Avatar
MB
Member
That's the way the ECU works, Dave. It's more efficient for it to do that, rather than try and aim for a set mixture. So the mixture is actaully changing.
Once the car is full throttle, it stops flip flopping and the injectors stay wide open and the fuelling is controlled on pressure, as the injectors couldn't pulse quick enough to time it right.
Old Jan 28, 2010 | 12:29 PM
loftust's Avatar
It would have to be converted from A-D though...there isn't clockwork inside that ECU
Old Jan 28, 2010 | 12:39 PM
energetic's Avatar
^Great link. I suggest to read this one as well. It includes some information for the lambda sensor.
http://en.wikipedia.org/wiki/Oxygen_sensor
Old Jan 29, 2010 | 12:35 AM
MarkB's Avatar
Depending on how technical you need to go, this pdf might help (lots of detailed information on the probe itself);
http://www1.tu-darmstadt.de/fb/ms/studium/...LambdaProbe.pdf
