Lambda Sensors
Old Jan 29, 2010 | 01:23 AM
lower's Avatar
Originally Posted by loftust,Jan 28 2010, 09:29 PM
It would have to be converted from A-D though...there isn't clockwork inside that ECU
The signal is already effectively digital as it only gives a high and a low voltage.
If its high then the ecu adjusts the mixture one way. If its low it adjusts the mixture the other way. When its reached its optimum the sensor is flicking from high to low.
The ecu doesn't know how rich or him lean the mixture is, just that it is rich or lean.
Old Jan 29, 2010 | 01:57 AM
Nick Graves's Avatar
It's effectively a dynamic feedback loop.
There's little point in aiming for a constant stochio, since load and TPS and temp will be constantly changing accprding to driving conditions.
Old Jan 30, 2010 | 12:46 AM
arsie's Avatar
The ECU will need to be different for zirconia (0.2v-0.8v) to titania (0.01v-4.5v).
Apart from the voltage levels per se, titania sensors provide a step on/off signal transition rather than a continuously varying level, as I read it. In which case the ECU will need to interpret things rather differently. Mark?
Old Jan 30, 2010 | 02:14 AM
MB's Avatar
MB
Member
Correct Mr Rog.
0-5v sensors are commonly called "Wideband" and can't be interpreted by the ecu, unless it was designed to. So we couldn't put one on the S for example.
I had one on my first S, but it was a clever one which also gave a normal 0-1v (narrowband) output to keep the ECU happy, but I could get the 0-5v Wideband readings in the car to get a good idea of the AFR
Old Jan 30, 2010 | 02:53 PM
loftust's Avatar
Some very useful info...thanks chaps
trig06
Feb 2, 2019 04:08 AM
Croc
Apr 14, 2014 04:01 AM
wotto1
Jul 6, 2007 05:32 AM
F20_C
May 20, 2007 12:30 PM
