Speed bleeders
Old Aug 11, 2011 | 10:31 AM
oxhouser's Avatar
Default Speed bleeders
I'm getting the bits together to change brake fluid and have come across these speed bleeders, basically you replace the bleed nipple for one with a built in check valve, this allows you to bleed them yourself
I haven't seen them before but they are made by goodridge so should be ok and at around £25 for 4 it's not a money decision
Seems some guys who track their cars use them to run some fluid out of the callipers during the cooling off period
Any body used them or have an opinion?
Old Aug 11, 2011 | 10:18 PM
veehexx's Avatar
i've never used them, but they seem pointless.
might aswell just get a no-return bleeding kit; atleast you can use it on more than your current car.
Old Aug 12, 2011 | 05:21 AM
Chris Type R's Avatar
I've got one of these in the garage - http://www.halfords.com/webapp/wcs/s...egoryId_165727
Seems to work okay - no pumping pedals etc - but one does have to use low tyre pressure to operate it.
Old Aug 12, 2011 | 06:01 AM
razzele's Avatar
Not very relevant but I ve got one of these- very easy to work with.
Old Aug 12, 2011 | 06:53 AM
Ultra_Nexus's Avatar
Interesting! Quite sensible, but a bit overkill.
Old Aug 13, 2011 | 12:14 AM
Dembo's Avatar
WHS. You'll want to attach a pipe anyway (unless you're planning on pissing brake fluid everywhere), so you may as well attach a pipe with a valve in it and you've got exactly the same thing.
Old Aug 13, 2011 | 02:23 PM
Hockenheim's Avatar
Bought something similar to this and it is very easy to use http://www.tooled-up.com/Product.asp?PID=109708
I do not put the brake fluid in the container of the device but top up the reservoir in the car with brake fluid and use air pumped by the device to bleed but I avoid going below minimum level in the reservoir to avoid air getting in the system as a precaution. If you put brake fluid in the device and use it as intended, it is probably easier to use but then I don't have to clean out the device.
Old Aug 14, 2011 | 01:05 AM
veehexx's Avatar
people do realise that oxhouser is speaking of http://www.speedbleeder.com/, and not bleeding kits?
beechx1
Oct 26, 2016 04:48 PM
RavynX
Mar 11, 2010 08:35 AM
Lord-Jaffa
Feb 27, 2009 07:51 AM
hondaf1
Jan 21, 2009 11:00 AM
aquatic
Feb 24, 2003 01:27 AM
