Starter motors
Old Sep 17, 2008 | 07:03 AM
FistralG's Avatar
Originally Posted by Dembo,Sep 17 2008, 01:09 PM
The Primera won't start . The starter turns, but obviously isn't engaging as you can hear it spin much faster than usual.
Any suggestions?
Ta.
I had this problem on an old Mini...turned out the battery wasn't holding charge and there was only enough charge to spin the starter motor but not 'throw' it across to engage with the flywheel ring.
Can you jump it with booster cables from another vehicle?
If you can't then I'd agree with Lower on a possible diagnosis.
Old Sep 17, 2008 | 07:22 AM
Dembo's Avatar
Thanks, but I doubt it. I had the battery go flat a while back and even then it was still managing to turn over the engine, albeit slowly and painfully. I replaced the battery on that occasion, so the one that's in there is pretty new.
Old Sep 17, 2008 | 08:06 AM
lower's Avatar
Mini's had an inertia starter where the start motor spinning threw the pinion out into contact with the ring gear.
Modern pre-engaged starters don't work quite the same way.
jordaninabox
Jun 29, 2012 04:28 PM
dezignpro04
Dec 30, 2008 09:37 PM
kartrcr4life
Sep 15, 2008 05:50 PM
gerardog
Nov 24, 2004 12:01 PM
Y2K1S2K
May 30, 2001 09:57 AM
