Variable Valve Timing
Old Feb 26, 2007 | 06:07 AM
  #21
smnasn's Avatar
Bu as Dembo said, the Rover VVC engines had continuously variable lift and duration...that aspect of the engine at least was quite advanced.
Old Feb 26, 2007 | 06:17 AM
  #22
Nick Graves's Avatar
No they didn't quite -lift was constant.
The duration of the cams relative to one another was variable (concentric camshafts).
It was a good idea, potentially - another 1/2 way house to full CVTEC.
Old Feb 26, 2007 | 06:34 AM
  #23
smnasn's Avatar
Duh of course you are right it was duration only! Nevertheless it was an interesting idea, and leaving aside the fact it sounded like a bag of nails the VVC engine in my Elise was a pleasure in the way it made its power. A good idea wasted as only Rover could do...
Old Feb 26, 2007 | 07:30 AM
  #24
Bada Bing!'s Avatar
Banned
You don't think Rover came up with that themselves do you? Wasn't it Yamaha who designed their engines for the last 10 or 15 years before they went tits up?
Old Feb 26, 2007 | 08:08 AM
  #25
smnasn's Avatar
As far as I know the K series was designed by Austin Rover and funded by the good old UK tax payer...
They were of course in collaboration with Honda at the time and the govt wanted them to use Honda engines, but Tebbitt was persuaded to fund the K series...
Old Feb 26, 2007 | 08:25 AM
  #26
True.
VVC was not developed for the same reason the plastic head dowels were not changed...
Not a pot to piss in.
Later, the NG BMW/Rover engine would have replaced the K, but BMW ran out of patience very quickly.
Hence the Mini used a Chrysler engine, latterly a Peugeot.
Old Feb 26, 2007 | 08:43 AM
  #27
lower's Avatar
Originally Posted by Kobe,Feb 26 2007, 02:41 PM
weren't renault the first to go with pneumatics replacing the springs on the valves.. more than 20years ago when 13,000rpm was a lot.. I think it was Senna's Gerard Ducarouge designed lotus..
however the amount of complexity and horsepower loss from the compressor doesn't make sense unless you are going for max revs/power.
that was purely to replace the valve springs though as even the best metal springs couldn't close the valves quickly enough once the engine revs went higher than 13k revs. I wasn't aware that it required a compressor though. Don't they just operate from a reservoir of compressed air?
Desdronomic valves are the way to go for high revs, if you can make them work effectively.
Old Feb 26, 2007 | 08:46 AM
  #28
Bada Bing!'s Avatar
Banned
Why have Honda and Toyota/Yahama stayed just below 9krpm for all their new engines? How come they haven't kept going with the stratospheric numbers and gone into 5 figure territory?
Old Feb 26, 2007 | 08:49 AM
  #29
Tightening pollution regs.
Things tend to get messy @ high RPM anyway, plus; ever wondered where all the oil goes if you thrash it continually?
Old Feb 26, 2007 | 08:54 AM
  #30
smnasn's Avatar
Also, taking my 14000rpm ZX6R engine as an example (and it's a lot easier in a small short stroke engine) it has 1500 mile service intervals and I suspect an engine with 30-40k on it would be pretty shagged...
(Ironically my Ducati with desmo valves only revs to 8000rpm, but then I believe they fit them in tractors in Italy ... )
