Alignment Shop
Hi Guys,
I'm going to be putting on my coil overs soon and will need an alignment post install. I'm planning an altering the specs a bit to be more Euro spec. Can anyone recommend a shop that will not only preform the work correctly but not beach and moan about not using factory spec.
fyi...I've got Bilstein PSS9s
Todd
Todd
Todd, I have been very happy with Eurowerks/Zuffenhaus in Matthews, NC. They are a service/race shop and will align and corner balance to any spec you want. They just finished with mine and did a great job. You can reach them at:
www.eurowerks.us
340 Seaboard St # A
Matthews, NC 28104-8120
(704) 821-3061
www.eurowerks.us
340 Seaboard St # A
(704) 821-3061
Where do you guys get your alignment specs from? I would like to go a little more aggressive with my alignment (stock suspension) but don't really know what specs to use for "spirited street" and mayby autox.
By the way Todd, i am jealous of you. I want a set of PSS9's so bad!!
Front Castor: 6.45
Front Camber: -1.0�
Front Toe: 0.0�
Rear Camber: -2.0�
Rear Toe: 0.20� total 0.40
There are many threads on the board about them if you do a search. Double check to make sure these are correct, but they look right to me.
I second the guys at Eurowerks/Zuffenhaus. I took my Vette there after the Chevy dealer tried to align the car and failed. They did an awesome job, they worked on it until it was perfect. I plan to use them again if/when I need it. They mostly work on Porsche and BMW cars, but they will align most cars and mount and balance tires too.
