Anyone using Kpro in NC?
There seems to be a lot of debate on whether Kpro will pass inspection. While no CEL are thrown, the testing computer can detect that it is a RSX PRB ECU and this has raised issues in some states. Has anyone in NC passed inspection (w/o a hook-up) with a Kpro?
you have to make sure to put the vin number in on the kpro. At least with the k-series cars if you dont do that then it wont pass. I'm not sure if it would pass w/the S being a different ecu and all. Thats where i would start.
I dont' have direct experience specifically with your subject but I do have a general idea. My suggestion is that if it comes down to it, you can either use a VAFC in conjunction with the stock ECU is using aftermarket injectors to scale them down during inspection. Or you can do the match and reduce the base fuel pressure through an adjustable FPR accordingly with the stock ECU. That's assuming that you would need the stock ECU by itself to pass inspection..
^well you cant really properly scale the duty cycle on larger injectors with just an afc, although I suppose using the fpr to lower the fuel pressure well below stock would hold them back. As far as passing the inspection goes, the ecu should work fine as long as the crank sensor etc etc has been matched and replaced to be complient with the kpro. Im not sure if these odb2 ecus work this way, but you may just have to have the new vin flashed into the computer. North Carolina in particular is rediculous with their emissions laws and I have learned to just suck it up and get the car down to stock and get it passed. Very time consuming, Yes. Effective, yezzir. I know there are a couple guys running kpro in California, Ill have to see who it was and ask what they are doing to get by...
you can make injectors about 2x the size of stock work with a vafc.. just remember that it severly throws off the ign timing.
I would keep your money, go aem and slap the stock ecu and injectors in when its time for inspection
CHEETAH_S2K
May 13, 2004 12:11 AM
ultimate lurker
Jul 26, 2001 11:45 PM
