Crunching Noise
Back from the dead.
I had good luck with not replacing them but just tightening them back up with an impact gun, and then re-tanging the nut. This is what I also did for Ryan's car to fix this very problem above. Pop off your rear wheel and you will see a big nut (I believe 34 or 36 mm), that is the axle nut that you will tighten.
Good Luck,
Craig
Good Luck,
Craig
thanks 2 Steve and karl and to the guy who drove from fayetnam this morning (I forgot your name again
I'll tighten this bolt soon and report the prog.
I'm glad I came out this morn to the meet, wish I could have stayed for the rest
)I'll tighten this bolt soon and report the prog.
Originally Posted by my2ks2k,Mar 11 2009, 08:06 AM
just an FYI...re-torquing the axle nut after you've heard the noise isn't a "fix"
it's a bandaid. you could have a bearing going bad, in which case the noise will be back.
Ps your welcome Ryan(one of my satified "band-aid" recipiants.)
Originally Posted by mouseS2000,Mar 11 2009, 10:11 AM
I have done this to my personal car and to three other S2000's and none have come back. I had put over 10K miles on my "band-aid".
yeah yeah I know it took me over a month, but I finally took care of this issue today.
I had another mechanic buddy change out my brake pads, and I showed him what I wanted done with the axle nuts, and had to face a wtf look from him and another mechanic at the shop, and their explainations about how greasing these axle nuts really wouldnt do much- but you know what? It worked! and they were surprised.
Noise is gone.
Hopefully it will be quiet for a long while.
Noise is gone.
I know that when you go to tighten the nut, before would be a good time tolube the splines of the axle,then tighten it. it makes it easier for the nut to pull it tight when you tighten it. this is a honda service bulletin. had a certified honda mechanic show me this.
