i need a 06-09 oxygen sensor...pref local pickup
Old Oct 11, 2011 | 03:44 AM
miguel329's Avatar
Default i need a 06-09 oxygen sensor...pref local pickup
i need a 06-09 primary o2 sensor! when i got car dealership put new o2 in car... well decided go turbo... go take the o2 sensor out someone cross threaded the damn thing... spent all last nite trying to carefully dremel out... but its completely messed up... im in myrtle beack sc... pm me...
Old Oct 11, 2011 | 03:57 AM
RedCelica's Avatar
Why don't you just take it back to the installer and make them fix it?
Old Oct 11, 2011 | 04:12 AM
miguel329's Avatar
becuase called honda... they said no possible way one of their "trained" techs would cross threaded a sensor... when i purchased car from another dealer they sent me to honda to have o2 sensor replace and they paid for it... that was in feb, since then i never had a need to get the o2 sensor out, till this past week..
Old Oct 11, 2011 | 04:41 AM
RedCelica's Avatar
Ah, I see...I just had mine replaced last week after a failed cat. ate my o2 sensor. Thankfully it was all under warranty though.
At any rate, gl with the fix. Could you use an anti-fouler to just fix the problem?
http://honda-tech.com/showthread.php?t=2162223
Old Oct 11, 2011 | 04:49 AM
miguel329's Avatar
i would but im doing etune jeff evans needs it working i found one on amazon for ok deal not sure if its correct one
Old Oct 11, 2011 | 04:56 AM
batguano's Avatar
Is this the O2 that is in the cat? If that was X threaded, you may need a new cat as well.
Old Oct 11, 2011 | 05:58 AM
miguel329's Avatar
no primary is one in the manifold
Old Oct 11, 2011 | 07:01 AM
japhethwar's Avatar
Just run a tap through the bung before you screw in the new sensor. Stripped out sensors are super common. Probably 4 of 10 I replace are stripped. Tap size is 18mm x 1.5. I would recommend an oem sensor as well. We've had lots of issues with aftermarket or different than oem sensors on a variety of different cars. Some show no issues with off brand sensors and some will set cels almost immediately. Always best to use factory parts if possible. If you were in greenville i'd let you borrow the tap, but it shouldn't be hard to find. Good luck. Oh and good choi e letting evans tune the car. He did my turbo car couldnt be happier.
Old Oct 11, 2011 | 07:12 AM
miguel329's Avatar
thanks jap i ordered the denso 234-9065... couldnt believe o2 sensor is $300! found on a discount site for $140 shipped i just need it to last me for the tune, i have a aem wideband i plan toss in after etune... i didnt know i would need oem one for him to calibrate the engine or i wouldnt of gave my spare one away lol....
Old Oct 11, 2011 | 10:48 AM
miguel329's Avatar
well japhethwar evans said cancel my denso replacement order and get oem from dealer... $204 for that o2!! he said oem actually very accurate sensor.
DJ Maestro
Aug 22, 2012 06:11 PM
Daren 83
Jul 22, 2011 12:34 AM
jshimer23
Jul 7, 2011 03:40 PM
ZDan
Sep 14, 2007 05:05 AM
