I've got the dreaded...
Old Oct 30, 2007 | 05:18 AM
MyBad's Avatar
Default I've got the dreaded...
I woke up with it one morning. I remember seeing a post where a guy used padded foam material to quiet the beast but I can't find it now.
Can anybody help?
Old Oct 30, 2007 | 05:20 AM
my2ks2k's Avatar
no idea where the thread is addressing this, but i just folded up some thick paper and stuffed it between the outer and inner sections of the latch (if you grab ther outer section and wiggle it, you'll see what i mean.) probably anything you can stuff in there would work fine
Old Oct 30, 2007 | 06:25 AM
MULDER's Avatar
Yes, I used padded foam to quiet the rattle. Phil, if you feel the sides of the latch you should be able to make is slide around a little. That is what is rattling. Take a peice of the padding and, using a small screwdriver, force the padding between the thin metal side and the thicker metal side on each side of the latch... make sense? Take a look at it and you will see what I mean. That will get rid of it.... atleast for several years. Mine has come back within the past month so I need to do mine again. It takes all of 30 seconds.
Old Oct 31, 2007 | 04:54 AM
MyBad's Avatar
Thanks, guys.
Old Oct 31, 2007 | 12:07 PM
GyozA's Avatar
Can't you latch them at the same time? Mine did it for a while. Put equal pressure on both of them and it stopped.
Old Oct 31, 2007 | 12:12 PM
my2ks2k's Avatar
NA
Old Oct 31, 2007 | 12:30 PM
MULDER's Avatar
Yes but this is a different rattle. It isn't the actual top Knocking against the strikers its the little pieces of metal on each side of the latch that are moving laterally and making a ticking noise.
Old Oct 31, 2007 | 01:47 PM
parkerdt's Avatar
Get new strikers - hardtopguy can fix you up!
Dave
Old Nov 4, 2007 | 07:23 PM
Yflyer's Avatar
Try this TSB on Top Rattles
It shows how to stuff the double sided tape into the latch body
Old Nov 5, 2007 | 05:54 AM
HOTRODS2000's Avatar
I guess you could always move to something with a fixed roof.
Sure do miss this site and the great people.
