loud sounds coming from my engine
there is a loud springing sound coming from my engine when i idle someone told me its common on s2ks and i was wondering how to fix this and what part it is
haha yeah good luck ljsimp took his out i sandblasted the worm gear for him he said sounded good as new. he said he tried sanding it but i couldnt tell when i saw it. its hardened so it needs to be blasted let us know. gl
nick p
nick p
Consider buying one straight-up from billman250 on the boards. He is a top-notch, and well-respected mechanic on our boards (member/owner in the NYC area). Bill re-tools the same worm gear with a better tensioner spring. It is an easy swap/fix part. PM him
- Dave
PS. Please appreciate that folks here are recommending you change the TCT simply based on your description of "... loud springing sound coming from my engine when i idle...". Without a proper mechanical diagnosis, please understand that it *could* always be something else. However, the TCT can often be the culprit of such described engine sounds. Here is a thread with all the TCT info (questions by owners...answers by Billman250) that you might ever want to know
https://www.s2ki.com/forums/index.ph...&f=22&t=320897
- Dave
