New s2k owner in High Point NC needing help!!!
You could switch out your belt for a new one. Its very easy. There is a belt tensioner which you use a wrench to take the tension off the belt then you can pull it right off and put on a new one. Should solve your problem.
Awesome, ill get that belt swapped out this weekend! Then im doing ALL the fluids in the car. I noticed the gears are kinda notchy at times so im sure the tranny fluid is cause of that. Look forward to seeing everyone at the Dragon!!
AP1_FC3S
21
09-04-2009 05:07 PM
jib2222
55
08-08-2007 04:33 PM
