Spark plugs, gap them please
Old Oct 10, 2011 | 03:12 PM
americandrug's Avatar
Default Spark plugs, gap them please
Just a reminder to gap your spark plugs before you install them.. I purchased a set of NGK Platinum laser plugs about 5 months ago. The guy at advance auto told me they were a pre-gapped set and i shouldnt worry about it. So a few days ago i get 4 CEL's and my S is running like crap, drop in power, engine feels like its hopping on the road in first at low rpms, smelled like burning plastic. Got an obd reader and checked it out, had multiple misfires, cylinder 1, 3, 4, and the multiple misfire code p1399. Like anybody else im freaking out thinking the coil packs are about to blow, pulled all the plugs and noticed 3 of them were burned to a crisp. I was really concerned because the plugs are rated for 70,000 miles. All in All i picked up a set of NGK Laser Iridium for $36 bucks and gapped them myself, .044. So please do check your plugs before installation.
Old Oct 10, 2011 | 05:12 PM
RedCelica's Avatar
I'd be interested to know what the post-crispy gap was.
Just a word of advance to those reading...you should never put ANYTHING other than Iridium plugs in the S. jm2c.
Old Oct 10, 2011 | 08:13 PM
Ultimate_Combination's Avatar
um...Autozone advice ≠ anything S2000 related!
Old Oct 11, 2011 | 03:42 AM
wadzii's Avatar
Banned
if there is a -11 at the end of an NGK part number that means they should be pre gapped to 0.044.
if you get the same plug with out the -11, the gap will be between 0.030 and 0.035 usually.
Old Oct 11, 2011 | 07:48 AM
TPhong's Avatar
Originally Posted by RedCelica
Just a word of advance to those reading...you should never put ANYTHING other than Iridium plus in the S. jm2c.
OEM plugs are platinum, so platinum will do fine, but Iridium if you're looking for an upgrade.
Old Oct 11, 2011 | 09:09 AM
RedCelica's Avatar
idk dude...I've seen several users on the board having misfires until they upgraded to iridium (as demonstrated by the OP). I'm just saying...if you're going to put plugs in it, imho, they should be irdium.
side note: Torque them to 18 lbs, the old specs are no joy (@ 13lbs).
Old Oct 11, 2011 | 09:16 AM
wadzii's Avatar
Banned
With gasket seat plugs you need to torque them then loosen then retorque.
I'd also suggest running the gap a bit tighter than stock
Old Oct 11, 2011 | 10:04 AM
04Briggs's Avatar
Op was talking about the gap, not the material. The biggest difference is going to be in how long the tips takes to erode and price. As long as the gap, heat range, and resistor type is the same, you should be good. I've heard people say that honda told them not to use iridium and people say that the tips break on the iridums but that's still what I use.
Old Oct 11, 2011 | 10:07 AM
04Briggs's Avatar
which plugs did you get the first time that you were having trouble with?
Old Oct 11, 2011 | 10:17 AM
04Briggs's Avatar
I'm just wondering if you got non resistor plugs. When I have my 3000gt they sold me some "oem" plugs and I had some similar issues as you. Turns out I had the wrong type resistor and ended up paying 600 to have them changed again! That car was a PITA to work on though.
