yo from pa
Old Jan 13, 2008 | 05:15 AM
fast-or-move!'s Avatar
Default yo from pa
hey guys new posting here but the guys up north don't know what my problem could be. my clutch pedal gets soft every once in a while and no one knows why. its a stage 2 full face clutch. someone said that one of the teeth could have lost it's strength , someone else said that a bolt could be loose on the clutch. i have no idea but the pedal feels fine then every once in a while it will get REALLY easy to push down but the trans doesn't grind goin in or out of any gear it just goes funny for about 5 minutes then it goes back to normal. any help would be great thanks
Old Jan 13, 2008 | 06:26 AM
ricosuave's Avatar
have you take the slack out of your throttle cable?
Old Jan 13, 2008 | 06:44 AM
how would taking the slack out of the throttle help my clutch pedal?
Old Jan 13, 2008 | 07:33 AM
ricosuave's Avatar
clicky.
have you checked your fluids?
Old Jan 13, 2008 | 10:01 AM
fluids are full but it's not my throttle that is acting up it's the clutch pedal. not much of a mechanic but i don't know if the pedals run off of the same cable.
Old Jan 13, 2008 | 11:40 AM
smitdog's Avatar
i would try bleeding it again .. might be air in the line ..
Old Jan 13, 2008 | 06:09 PM
whitemistress2k's Avatar
Sounds like clutch master cylinder going bye-bye... Soft/mushy pedal feel is the first sign.
Old Jan 14, 2008 | 01:42 AM
Dressed2Kill's Avatar
I would replace the master cylinder and slave cylinder.
Old Jan 14, 2008 | 01:44 PM
even if it's only happend a couple of times but not constant?
Old Jan 14, 2008 | 02:02 PM
Not an expert on it, but as I understand it, yes unfortunately ... Thats where I'd look at replacing first
