Computer problems :(
Old Jan 27, 2005 | 11:21 AM
p0pe's Avatar
Default Computer problems :(
Dear Tech Support:
Last year I upgraded from Girlfriend 7.0 to Wife 1.0. I soon noticed that the new program began unexpected child processing that took up a lot of space and valuable resources. In addition, Wife 1.0 installed itself into all other programs and now monitors all other system activity, such as Poker Night 10.3, Football 5.0, Hunting and Fishing 7.5, and Racing 3.6. I can't seem to keep Wife 1.0 in the background while attempting to run my favorite applications. I'm thinking about going back to Girlfriend 7.0, but the uninstall doesn't work on Wife 1.0. Please help!
Thanks,
A Troubled User. (KEEP READING)
______________________________________
REPLY:
Dear Troubled User:
This is a very common problem that men complain about.
Many people upgrade from Girlfriend 7.0 to Wife 1.0, thinking that it is just a Utilities and Entertainment program. Wife 1.0 is an OPERATING SYSTEM and is designed by its Creator to run EVERYTHING!!! It is also impossible to delete Wife 1.0 and to return to Girlfriend 7.0. It is impossible to uninstall, or purge the program files from the system once Installed!
You cannot go back to Girlfriend 7.0 because Wife 1.0 is designed to not allow this. Look in your Wife 1.0 manual under Warnings-Alimony-Child Support. I recommend that you keep Wife1.0 and work on improving the situation. I suggest installing the background application "Yes Dear" to alleviate software augmentation.
The best course of action is to enter the command C:\APOLOGIZE because ultimately you will have to give the APOLOGIZE command before the system will return to normal anyway.
Wife 1.0 is a great program, but it tends to be very high maintenance. Wife 1.0 comes with several support programs, such as Clean and Sweep 3.0, Cook It 1.5 and Do Bills 4.2.
However, be very careful how you use these programs. Improper use will cause the system to launch the program Nag Nag 9.5. Once this happens, the only way to improve the performance of Wife 1.0 is to purchase additional software. I recommend Flowers 2.1 and Diamonds 5.0 !
WARNING!!! DO NOT, under any circumstances, install Secretary With Short Skirt 3.3. This application is not supported by Wife 1.0 and will cause irreversible damage to the operating system.
Old Jan 27, 2005 | 11:31 AM
Superbabe's Avatar
That is so YOU
Old Jan 27, 2005 | 02:09 PM
AZWILDCATS's Avatar
Dear Troubled User:
It seems that you're support issue could be the result of an End User problem. Please search for and press the ANY key. If you are unable to locate, please defrag your system and reinstall GF 7.0. In the event that you continue to sustain technical support issues, please locate the nearest available 12 year old to assist.
Our Tech Support is available 24 X 7.
GCUS
Old Jan 27, 2005 | 02:29 PM
revhi's Avatar
Your Wife 1.0 program seems to be running fine. I think its your actual "PC". It might help if you go out and work on a "Laptop" once in a while.
User Warning: Never bring the Laptop home!
Old Jan 27, 2005 | 03:17 PM
racer chick's Avatar
:roflmao great dusty!
Old Jan 29, 2005 | 06:13 AM
luckys_gal's Avatar
I think it must be your HARDRIVE is lacking in Ram
Old Jan 29, 2005 | 06:14 AM
s2kbrian's Avatar
The Raptor
Apr 17, 2006 12:08 PM
johnny
Feb 5, 2006 01:03 AM
VFROOOM
Dec 26, 2004 08:34 PM
AquilaEagle
Mar 17, 2003 11:37 AM
