S2000 tire physics question... need an answer.
Old Aug 1, 2005 | 12:54 PM
jedwards's Avatar
Originally Posted by mikes2k,Aug 1 2005, 01:52 PM
I do what I can for the
Old Aug 1, 2005 | 12:56 PM
jedwards's Avatar
Originally Posted by PeaceLove&S2K,Aug 1 2005, 01:50 PM
BTW, stupid question, but do you think it would be possible to temporarily compensate for the tread difference by slightly over-inflating the left rear tire, and slightly underinflating the right rear?
I should consider overinflating the right rear since it's older and has a smaller dimension AND it's going in the trash.
Old Aug 1, 2005 | 01:03 PM
PeaceLove&S2K's Avatar
I could be wrong, but I believe underinflating (to an extent) = larger contact patch right?
You should experiment with various configurations and see which works best.
Old Aug 1, 2005 | 01:19 PM
mikes2k's Avatar
James and/or Rich should be by soon to correct the spelling of tires!
Old Aug 1, 2005 | 01:23 PM
Or Tim.
Old Aug 1, 2005 | 01:30 PM
jedwards's Avatar
Well you're right that underinflating creates a larger contact patch but since Billy is talking about 'moments' he's referring to the radius of the tire. Moments mean that something with a 2 lb push on the end of a a 2' member (here comes Mikey to explain what i mean by 'member') has the same effect at the other end as a 4 lb push on the end of a 1' member.
Hence I'm trying to increase the diameter not the patch.
jedwards's Avatar
^ he said "Hence" in the Corner.
Old Aug 1, 2005 | 01:31 PM
jedwards's Avatar
Ooops. I meant 'tyre'
Old Aug 1, 2005 | 01:37 PM
mikes2k's Avatar
Well you are now a paid member.
Old Aug 1, 2005 | 01:38 PM
mikes2k's Avatar
Oh you meant the other meaning of member
