Delaware Valley S2000 Members Delaware, Eastern PA (Philly)Southern New Jersey
Compression Test
Old Jun 16, 2008 | 10:52 AM
jshimer23's Avatar
Default Compression Test
Ok, so I changed my spark plugs (75k miles) this weekend and decided that while I was at it, why not do a compression test. The car was "warm" when I did the test. I followed the DIY and these were the results I got (each result is an average of 3 tests per cyl)...
Cyl 1 -- 251
Cyl 2 -- 250
Cyl 3 -- 242
Cyl 4 -- 253
Isn't a "normal" reading supposed to be 228? Now I know results can change from tester to tester but should the readings be that high? Also, should I be concerned that Cyl 3 was that much lower then the other 3?
The spark plugs looked pretty normal. They did however have some burn marks on the white porcelain part...Anyone have any insight on this or should I just shutup and go back to my hole?
Old Jun 16, 2008 | 03:24 PM
Mr. Francesco's Avatar
It says here 240 is the magic number, which is about what I thought was normal.
https://www.s2ki.com/forums/index.php?showt...&#entry13248148
I think you are fine.
Old Jun 16, 2008 | 05:33 PM
jshimer23's Avatar
thats what i thought. just wanted to make sure. i had just never seen readings that high posted. thanks!
Old Jun 16, 2008 | 06:25 PM
AssassinJN's Avatar
You're not far enough off to be of any worry. And #3, while lower, is not bad enough that I'd worry either (3.2% deviance).
Old Jun 17, 2008 | 04:55 AM
jshimer23's Avatar
I was just a bit surprised the #'s were as high as they were considering the milage on the motor and the fact that I don't exactly "take it easy" on her. I know a leakdown test is a better indicator of things but I just don't have the equipment to do that on my own...yet...
notaloafer
Mar 1, 2013 07:36 PM
exodusx7x
Jul 13, 2011 09:25 AM
pd0019
May 1, 2010 02:55 PM
HondaS
Jun 12, 2007 02:11 AM
nutar
Feb 20, 2007 02:56 PM
