Got the clicks, need help.
So far the car is great and all, but it has a case of the clicks from the rear. It looks like most have solved this by just tightening the rear spindle nuts. Ok, no problem, except that I do not possess a large enough socket (at least >32mm) and a torque wrench that reads 220 ft-lbs. Does anyone here have the tools/space/time to help me out with this simple fix? I come with beer!
Originally Posted by jmargelo,Apr 16 2006, 05:16 PM
I had the same issue of not having the proper tools to do it and just let Honda do it when I got it inspected. They charged me $20-30, and the clicks were gone.
Isn't there a TSB on that issue?
Originally Posted by Jason B,Apr 16 2006, 07:02 PM
Will this clicking hurt anything?
However, I would get the problem corrected right away to be sure that you are properly diagnosing the problem.
Bad CV joints is a different issue which causes the "shakes."
Be careful not to overtighten the axle nut as this is known to cause more imminent failure than it not being tight enough and dont forget the grease.
Originally Posted by tinkfist,Apr 17 2006, 10:50 AM
Er....how tight is too tight? I was going to have my 220 lb brother stand on the end of a 1' wrench. No good? Is there a special grease I should be using for this, or most any will do?
Your brother standing on a wrench is a bad idea. Adding an extension pipe to your torque wrench would be better, but still not ideal.
