Delaware Valley S2000 Members Delaware, Eastern PA (Philly)Southern New Jersey
What the hell is this sound!
Old Aug 9, 2015 | 07:06 AM
mattjung2003's Avatar
Default What the hell is this sound!
Please let me get your input on what is causing this sound.
https://drive.google.com/file/d/0B_8...ew?usp=sharing
Old Aug 9, 2015 | 07:19 AM
freq's Avatar
https://drive.google...iew?usp=sharing
TCT
It's been described as "baseball card in the spokes of a bicycle".
Sounds about right, no?
Old Aug 9, 2015 | 07:26 AM
rosica's Avatar
Sound like and exhaust leak, misfire or serious engine issue, If it goes away when the engine gets warm its probably an exhaust leak, otherwise check ignition & compression.
If it not those it is probably mechanical
Drain & strain the oil looking for metal
Pull the valve cover and look around for anything abnormal
-verify cam timing (unlikely, easy to check)
-check valve clearances (adjuster may have come loose)
-look for (common head issues)
--broken rocker
--cracked roller
--cracked valve retainer
Pull head to look at pistons and valves....
Drop oil pan to check bearings....
Unless you know it goes away when warm or find a loose/broken header bolt, I would pull the valve cover first before I ran the engine very much, checking spark plugs at the same time.
Old Aug 9, 2015 | 02:19 PM
Chuck S's Avatar
Playing card in the spokes sound it almost universally the TCT.
Ever replaced the Timing Chain Tensioner? How many miles on the car?
I put the Billman GenX TCT on my engine a month or two ago as preventive maintenance. Took 15 minutes with a 10mm ratchet spanner (not socket wrench). Never bothered getting into work clothes the job was so clean. Paper towel to catch a few drops of oil. OEM and other brands have a reputation of quickly failing. Billman's custom TCT has a lifetime warranty. Follow instructions exactly and here's no hassles. There's a core charge which was refunded the day he got my OEM TCT and bolts back to Long Island.
-- Chuck
Old Aug 10, 2015 | 05:57 AM
Thanks guys. I will look into the tct as the issue. I'll keep y'all posted.
Old Aug 13, 2015 | 02:48 AM
freq's Avatar
Did you get this sorted out or isn't the S your daily driver?
Old Aug 14, 2015 | 07:41 AM
The S is not my daily. I am in the process of getting the tct from billman. thanks guys.
Kumbi
Nov 4, 2011 06:51 AM
Mintyhit
Mar 25, 2011 09:59 AM
SloS13
Feb 25, 2011 04:45 PM
revto9k
Jul 11, 2009 07:21 AM
leets
Mar 29, 2007 02:09 AM
