cancel
Old Oct 29, 2011 | 08:34 AM
Kumbi's Avatar
Default cancel
cancel
Old Oct 29, 2011 | 10:04 AM
japhethwar's Avatar
Hard to tell could be many different things. Def would be pulling the valve cover before I attempted to even crank it again. Check the oil/filter for metal fragments. Doesn't sound good though. Good luck.
Old Oct 29, 2011 | 11:04 AM
TougeHorseman's Avatar
Sounds real bad..
Old Oct 30, 2011 | 11:44 AM
Kumbi's Avatar
the video does no justice. the sound is not as loud as it sounds.
Old Oct 30, 2011 | 07:14 PM
Kumbi's Avatar
buuuummmp
Old Nov 3, 2011 | 08:29 PM
roscoe's Avatar
Lol the car sounds like it needs a new motor. Jk
Old Nov 4, 2011 | 02:53 AM
flipsk8er2689's Avatar
Sounds like a loose nut somewhere inside the engine. Without compression from the valves/piston it wont start. Simple thing like that can cause you your whole engine....sad...
Old Nov 4, 2011 | 03:51 AM
EagleDon's Avatar
Pull the valve cover and see if all valves are intact and working properly.
Old Nov 4, 2011 | 05:19 AM
axus19's Avatar
last time mine sounded like that, 3 days later I went to start it and KabooM, i had an 4 inch hole on my engine.
Check your oil, mine was missing two quarters
Old Nov 4, 2011 | 06:51 AM
03 9g's Avatar
check the oil !!!
jc2078
Nov 21, 2012 05:14 PM
Kumbi
Nov 3, 2011 05:45 PM
SloS13
Feb 25, 2011 04:45 PM
TurboLex
May 10, 2010 08:25 AM
Bandit_287
May 28, 2008 04:43 AM
