Engine Swaps Discussion of alternate engine swaps into the S2000 other than F20/22. K24, 2JZ, V6, V8 etc...
Kwapped but no RPM+EPS light on.
Old Sep 11, 2019 | 01:42 AM
Falken12's Avatar
Default Kwapped but no RPM+EPS light on.
As stated above along with no oil temp reading. Speedo works but it would read half of my actual speed. Also when ECU is connected to the computer, it constantly reads 49mph even at a stop. EPS works but only after you get the car moving.
I’m reaching out for solutions before I dishout on a new Harness or Cluster?
Old Dec 5, 2019 | 05:34 AM
decepticondc5's Avatar
What ECU? What Patch Harness? There isn't really enough info for the community here to help out. If you have faceballs, check out the K swapped S2000 group. They are generally an extremely helpful community.
Old Dec 10, 2019 | 03:47 AM
theprophet36's Avatar
I had issues because the brand new speed sensor from Import Muscle was bad out of the box. Replaced that & my EPS/Speedo worked. Of course I had to correct the speed pulse with a Yellow Jacket.
Old Apr 10, 2020 | 10:25 PM
Michigan Maize's Avatar
For the RPMs, make sure you have tapped a wire into the S2000 A Connector position 19 blue wire to K Harness E Plug Position 27.
The vehicle speed is read from the VSS Sensor on the transmission. This is a 5V signal type. Make sure this is wired to the harness correctly and your ECU is looking for a 5V signal
Old Apr 10, 2020 | 10:37 PM
Falken12's Avatar
whoa, thanks my man. I’ll look into this.
Old Apr 11, 2020 | 12:19 PM
Any time. Let me know what you find
takasniper
Feb 26, 2019 06:17 PM
mcs2000si
Dec 28, 2018 07:49 PM
Topplayer
Nov 29, 2018 05:28 AM
MrSmith
Aug 15, 2018 02:53 PM
Johny
Apr 20, 2018 08:50 PM
