After 10hours
Well after 10 hours is in...............my new ACT stage2 clutch kit with a 8pound fidanza flywheel BTW "the stock fly wheel wieght 20 pounds"
is in and is sweet!!...I love it. WOW!! What a defference.
It was a bitch putting it in... even with a lift all the tools and shop conditions it sucked ass lol
If a had to do it over... now that I know what goes where... it would take me and my friend 6 hours
or less
I just want to thank Todd @ 2nrwerks for all the info he gave me about choosing a clutch. Also I want to say thanks to cmnsnse great write up on a clutch install.
Here is my bearing
The Disk
Pressure Plate
The 20 Pound FlyWheel
Well Well...I do not want to see a clutch for awhile...
or less
Here is my bearing
The Disk
Pressure Plate
My OEM flywheel was a little over 14 pounds
They must have used heavy metal in yours
....jk You may want to reset the scale you used to weigh it on.
I put in an Exedy Hyper Single clutch kit with steel flywheel. The flywheel weight is 11 pounds clutch and presser plate is also 11 pounds, total weight of kit 22 pounds.
The OEM clutch, presser plate, and flywheel was 28 pounds. I trimmed off 7 pounds total with the new kit
My old clutch looks very much like yours
Toasty
....jk You may want to reset the scale you used to weigh it on.I put in an Exedy Hyper Single clutch kit with steel flywheel. The flywheel weight is 11 pounds clutch and presser plate is also 11 pounds, total weight of kit 22 pounds.
Toasty
Originally Posted by FIdreaming,Oct 1 2006, 05:58 PM
Aww no pictures of the new parts??
Glad you are happy with the setup. So with a lightweight flywheel you can really tell a difference eh??
And to prove my stock fly wheel on my 2004 s2000 is 20 pounds.
I took a 25 pound wieght and put it on the scale as you see here
Flywheel
BTW Im just holding the flywheel up...
a couple dozen more clutches and you'll have it under 3 hours.
Good job, that disk is toast!!!!
Alot of hot spots on the flywheel and pressur plate as well.
Have you tried AC on and a passenger yet? That's the biggest test for me on a 8 lbs flywheel. Throttle response is great though isn't it?
Originally Posted by Bluebeast,Oct 2 2006, 12:37 PM
Is a be deference when you go from 20 pounds to 8pound fly wheel my car of the line just wants to go... i love it. Now with all that power i need to focus on my driveshaft and rearend.
Flywheel
Flywheel
Did you have to do a brake in with this clutch? like a few heat cycles or have to drive the car x amount of miles before driving hard on the new clutch?
I have staled the car a time or two as well with my Exedy
I too am trying to find that sweet spot so as not to look like a guy that can
news2kroller
Mar 27, 2008 09:26 AM
