check engine light
Old Jun 27, 2011 | 05:56 AM
Jony0110's Avatar
Default check engine light
i bought a test pipe for my car and the check engine light has popped up is there any way i can eliminate that light?
Old Jun 27, 2011 | 08:45 AM
PrimoGen's Avatar
bung for the O2 sensor on the test pipe...you have to back the sensor away from the exhaust flow or its going to throw that code everytime... you can create your own out of two sparkplug anti-foulers but you have to drill one out to allow the sensor a place to screw into.
there should be a DIY thread about it in the under the hood section of this site:
https://www.s2ki.com/s2000/topic/229.../#entry4560256
there it is
some test pipes have this issue addressed with a bung that is already welded in...if yours has this,. and you are still getting codes, you need to pull the code and make sure it not something somewhere else in the system
Old Jun 28, 2011 | 07:34 AM
Jony0110's Avatar
Thank you!!
aichan1234
Feb 4, 2011 08:19 PM
Popa
May 14, 2010 10:09 AM
S2K at 9K
Sep 3, 2007 10:02 PM
joeyriveira
Jun 16, 2003 07:14 AM
