HELP ME! problem with S
Old Oct 11, 2007 | 11:56 AM
MIAMI4QUAD's Avatar
Default HELP ME! problem with S
hello all... well i havent been driving the car much since i still havent replaced the top.. but heres the deal i noticed before i went to vegas that when i drive i let the clutch out it catches and if i ease into the gas it goes fine but if i ease into it and then stomp on the gas it barley moves??? when i got back from vegas i drove the car several times and it is a little worse than before.. this is kind of strange to me i have had several standard vehicles in the past and nothing has ever happend like this before.. i have replaced clutches in several mustangs before but they never acted like this?? any ideas?? any one want to drive the car to see what it is??
thanx for your time guys..
Old Oct 11, 2007 | 12:15 PM
jphish's Avatar
Sounds like you need a new clutch. How many miles are on your car?
Old Oct 11, 2007 | 12:17 PM
PrimoGen's Avatar
Thumbs down
does the car sound different when vtec engages?
does it feel labored when you go into vtec?
if so you may have more problems than the clutch.
<---speaking from experience
CHECK YOUR OIL LEVELS OFTEN!!!!!!!!!!!
Old Oct 11, 2007 | 12:21 PM
2NR Werks's Avatar
Clutch and/or clutch master cylinder. These should be changed in series when replacing a clutch.
Old Oct 11, 2007 | 12:22 PM
MIAMI4QUAD's Avatar
um the car has 45k...
the car doesnt sound different once in vtec there is no engine noise or anything.. its just really strange to me i have had clutches go out but never felt like this if it is infact the clutch... like when i hit the gas then let off again it will engage more.. like i said it is really strange to me
Old Oct 11, 2007 | 12:34 PM
MIAMI4QUAD's Avatar
if this is infact the clutch what should i go with??? how do i know for sure that it is the clutch.. like i said i dont know much about these cars and never owned an import before.. this is just very odd to me...
heres a couple links to clutches any suggestions??
http://www.modacar.com/products/Honda/S2000/MODACLS/
http://www.advancedclutch.com/1373352/0/0/...FI_(F20C1).html
Old Oct 11, 2007 | 01:19 PM
chartz's Avatar
i was told this was a common thing on the ap1's because I am sort of having a similar issue with mine!
jphish's Avatar
I would let someone who has had clutch slippage drive it. negcamber would be able to tell you. His clutch just went out.
As for what clutch to get,
NOT the "Competition Clutch"
Go stock.
Old Oct 11, 2007 | 01:22 PM
Sub-Zero's Avatar
Stock unless boosted!
Old Oct 11, 2007 | 01:37 PM
jphish's Avatar
