I need a HONDA tool
Old Jul 24, 2007 | 04:47 PM
S2KPUDDYDAD's Avatar
Default I need a HONDA tool
I need a SCS service connector Part number # 07PAZ-0010100
What this is, is a fancy wire jump used to clear codes from the SRSystem.
They only sell them to the dealer and not over counter
Help a brother out
Old Jul 24, 2007 | 04:53 PM
RadioZero's Avatar
you're more than welcome to try my CAN-Bus enabled scan tool. it might help, it might not. i can make a trip to brooksville, just let me know. what year is the car you are working on?
matt
Old Jul 24, 2007 | 05:15 PM
matt
Thank you but, a hand held will not clear this code SRS or DTC codes can only be cleared by Honda with there system or with this little jump plug that will erase the memory
Old Jul 24, 2007 | 05:36 PM
Elroy's Avatar
Off Topic:
oooooooooooooo , what' that?
J
Old Jul 24, 2007 | 05:51 PM
Originally Posted by Elroy,Jul 24 2007, 08:36 PM
Off Topic:
J
That is the latest PuddyMod It is a reinforced differential bearing cap
Here is a link to the zaniness
https://www.s2ki.com/forums/index.php?showtopic=509497
It is a one only experimental thing
Old Jul 24, 2007 | 05:54 PM
GinoGT's Avatar
There's a yellow plug with blue wires that plugs into a dummy socket (no connections, just holds the plug) by the fuse box underneath the driver's side dash.
I used speaker wire.....plug a wire into each pin of the plug (there's only two). Hold the other ends of both wires and touch them together, put the key in the ignition and turn it to the run position. The SRS light will be on. When it goes off, separate the wires in your hand. The SRS light will come back on, when it does, connect the wires again. It will go off again, separate the wires again. After this the SRS light will blink 3 times and (hopefully) stay off.
If the SRS light comes right back on, obviously, there is still a problem.
Old Jul 24, 2007 | 06:08 PM
Thanks I read I can do it this way but, I like to have the tool none the less
The code will clear I know why I have it, I did another VGS wheel swap and turned the key in the on position before connecting the air bag
Old Jul 24, 2007 | 08:24 PM
SiLvErMyS2000's Avatar
hey im from brooksville florida to and i went to gateway honda they will allow u to buy the $8 tool. I was gonna buy it to clear my code but it just keeps coming back on
Old Jul 25, 2007 | 12:26 AM
cool
myclue
Dec 21, 2013 06:29 AM
for_my_s2k
Aug 9, 2013 10:32 PM
copmagnet82
May 4, 2008 08:18 PM
Rawhide
Sep 19, 2005 03:49 AM
