LS2000
Old May 9, 2009 | 09:45 AM
pdexta's Avatar
Default LS2000
Not sure if this guy is on the site, or if this has been posted already. I was at a car meet in Naples last night when I saw a truck pull in the parking lot with an AP1 on a trailer. It turned out to be a V8 swap (I heard LS2 and LS6, not sure which), and it was on spray. The thing was sick. I know I've seen a few of these swaps in progress, but this was the first one I've seen running. They took it off the trailer and made a couple laps around the parking lot. It sounded insane. One of my friends got some pictures of it, I'll post them once he gets them online. Anybody else seen this thing around? Is he on the site?
Old May 9, 2009 | 11:09 AM
Sub-Zero's Avatar
LS shouldn't be to hard in a S2000 I've got one in a 78 280Z with a Ferrari body on it. Should premier it in the year 2030.
Old May 9, 2009 | 02:04 PM
yarbrough's Avatar
Way to set your goals high Good luck, I would like to see that!
Old May 9, 2009 | 04:45 PM
highwaystardoritos's Avatar
do you know what he used for his steering rack?
Old May 9, 2009 | 05:12 PM
Sub-Zero's Avatar
I have too many projects.
I would love to see a LS motor in a S2000. Hopefully it fits behind the cross member so no need for a different steering rack.
Old May 9, 2009 | 06:37 PM
thing is that its electronically controlled so if you want it all to work right you'll have to make both s2000 and ls1(whatever car you get it from) ecu to work. I'll probably just swap in a rx7 steering rack
Old May 11, 2009 | 04:46 AM
PrimoGen's Avatar
I bet when he corners the engine just keeps going straight
LOL
Old May 11, 2009 | 05:11 AM
scutrCR's Avatar
I think the engine is only about 150lbs heavier, thats totally acceptable. I might look into this swap when my warranty runs out.
Old May 11, 2009 | 07:15 AM
2big4aS2000's Avatar
you can just as much power or more with a turbo kit on a stock motor, i dont see the reason to go thru all that work.
Old May 11, 2009 | 07:17 AM
ITBs2k's Avatar
Cause an LS motor sounds much sicker than a turbo IMHO. haha.
