Need help...
Old Jul 27, 2007 | 10:03 AM
spectacle's Avatar
Default Need help...
https://www.s2ki.com/forums/index.ph...&f=22&t=511256
Post up your ideas/thoughts/solutions/whatever's!!!!!!!!! I'm tired of this crap
Old Jul 27, 2007 | 10:13 AM
Brownsound's Avatar
Bump for you, got me stumped!
timdonna1's Avatar
Sounds to me like you're on the right track. The only other thing I can think of is a computer problem.
Old Jul 27, 2007 | 10:48 AM
speedworksracing's Avatar
yea check compression. if the front is low then it will still fire just fire weak.
Old Jul 27, 2007 | 12:12 PM
Bandiscoot's Avatar
switch out a coil ... even with one next to it. If you can find another S2000 with good coils switch them out ... one-by-one ... and see if there is a difference. Coils are known for issues.
If that doesn't solve the problem ... then check compression. Even with 'good' though you could have a cracked valve seat or piston/ring. Also, valves can be bent slightly or be impeded by something ... enough to allow intake/exhaust to still breath. That also causes 'stuttering'.
hth
Old Jul 27, 2007 | 12:22 PM
negcamber's Avatar
Usually the misfire code comes back to injectors. But if you're sure it's not injectors, then definitely compression check and/or leak down. Might have a bearly tweaked valve or sticking rings.
Borrow some coil packs from a well running car to test yours...but that's fairly rare for them to go out on this car. And check the plugs to make sure they are oem...perhaps a previous owner put crap plugs in or used Bosch Platinums thinking they were better.
Old Jul 27, 2007 | 12:34 PM
fltsfshr's Avatar
It sounds to me like a weak battery or a bad ground. S's have little batteries but love electricity.
fltsfshr
Old Jul 27, 2007 | 06:31 PM
spectacle's Avatar
Plugs are def OEM, I put the NGK's in brand new last year. I pulled that one cylinder today, it is a little on the rich side but otherwise in good condition. I think the next thing I'll play with are the coils.
Old Jul 29, 2007 | 10:54 AM
spectacle's Avatar
also if it helps...flashing CEL/rough idle only happens when the motor/temp outside is hot. In the mornings or late evenings, its fine.
What gives?
Old Jul 29, 2007 | 11:43 AM
timdonna1's Avatar
What gives?
Mass air flow sensor
