Need new spark plugs
Old Jul 17, 2006 | 09:56 AM
spectacle's Avatar
Default Need new spark plugs
OEM replacments from sparkplug.com are $55 shipped...I can only imagine what the dealers around here want.
I wanted to get these NGK's (BKR7E-N-11) Rick recommended me but I called around and I can't find those anywhere. I have no problem getting regular copper tops opposed to the irdiums but I want to make sure I get the right ones.
I've got a test pipe install pending and the sparks need replacing so I'm planning to do the Honda cleaner at the same time before I dyno on the 5th but I need some plugs!
What are you guys running and where did you get them from?
- Darius
Old Jul 17, 2006 | 10:41 AM
PrimoGen's Avatar
DO NOT GET CHAMPION ANYTHINGS!!!
just heads up. Ask Rick 2 2nrwerks about my champion plugs
Basically when we went to remove them to replace with NGK 7's the plug in number 4 broke in half (not the ceramic part). The threads that hold the plug in seperated from the rest of the plug and was stuck in the engine.
Now, you are probably thinking to yourself "oh, the 6 point "nut" that you use to remove the plug was still attached so just unscrew it, right?" = WRONG!!
Just the sheath that has the threads on it was left in the chanber so we had to use an Easy-out and hope we did not destroy the head....we were successful but I will never...ever....ever,ever,ever,ever,ever,ever
put champions in my car ever again.
NGK's or bust IMHO
Hope this helps
Rick should be able to get you set
Old Jul 17, 2006 | 11:24 AM
S2KPUDDYDAD's Avatar
PM me
I have a set of Denso Inirum plugs with only 5K miles on them
Retail $60.00 with out shipping I will let them go for $40.00 They are still in the box they came in
Old Jul 17, 2006 | 11:49 AM
5thelement's Avatar
just stay with the ngks yeah there expensive but youre not driving just any car you need some good plugs
Old Jul 17, 2006 | 12:01 PM
M.A.R.C.'s Avatar
NGK's or bust IMHO
Hope this helps
i've seen that happen to ngk's as well.
Old Jul 17, 2006 | 12:02 PM
MacGyver's Avatar
I think I picked up double Platinum Iridiums from Autozone a while back for like $45... but I could also be smokin' somethin'...
Old Jul 17, 2006 | 12:04 PM
DeviousOne's Avatar
Its an S2000 suck it up and pay the 55 bucks for the spark plugs...:-)
2NR Werks's Avatar
We keep a replacement set of NGK in stock for the S2K at a much more affordable $15/set. This uses a new ceramic electrode that is placed lower in the plug an seems to run better. Primo and Alex, forgot Alex's screen name, just got this new plug in their motors last week. We will get an update on the performance from them soon.
I only had these two sets to try out, but more are on the way.
Darius, I will hold a set for you if you like. Reply here or PM me.
Old Jul 17, 2006 | 12:17 PM
PrimoGen's Avatar
Those that Todd are talking about are working quite well. Between those and my recent ECU reset, I have felt a good bit of throttle recovery.
Old Jul 17, 2006 | 01:15 PM
hygiene boy's Avatar
Even single electrode Bosch platinum is a good plug for $1.50 each at Autozone. As long as you stay name brand you're fine as far as quality goes. Denso , NGK, Champion, Bosch, they have all had a failure or two but it is very uncommon and probably caused by a plug that was dropped or damaged after the manufacturing process.
