oem hardtop
Old Aug 28, 2013 | 06:40 PM
gatorbait4me2000's Avatar
Default oem hardtop
hello
I installed an oem hardtop and there is a lot of rattling and noise coming.
I wanted to know if anybody has any suggestions or ideas on what to look for or
what I should check. thanks
omar
Old Aug 28, 2013 | 07:13 PM
__Ap2__s2k's Avatar
Easiest try is some shin etsu grease
Old Aug 29, 2013 | 02:57 AM
TardiS2K's Avatar
Check the installation manual for the h/t for the gap clearances (the gaps of the seals around the bottom) and make sure they are within Honda's specs.
Make sure the rear catchers are torqued down right. May need to replace the front catchers on the windshield though to really tighten up the fit. I was lucky and my soft top ones were enough.
GL
Old Aug 29, 2013 | 03:22 AM
dc50818's Avatar
Yea u prob need to put shims tomm the front bracket so it pulls the hard top down more and when u tighten the rear make sure someone is pushing down on the hardtop
Old Sep 2, 2013 | 08:31 AM
thraak's Avatar
If the top needs just a bit of tightening up, you can cut a 1/4 inch piece of clear plastic airline tubing, (from hardware store), and put it on the hook of the top's latch. Then, close the latch. It does tighten it up a bit.
Old Sep 3, 2013 | 07:48 AM
Blacknot's Avatar
I used heat shrink on the front hooks if the latches and seemed to help
fernando.
Oct 10, 2012 04:50 PM
Swift GT
Aug 19, 2012 06:53 PM
mitch rubbertramp
Jun 2, 2011 02:34 PM
PoLe_PoSiTiOn
Jun 3, 2008 07:12 PM
S2KrNBRuIn
Sep 11, 2006 08:20 PM
