PuddyMod wheel repair
Originally Posted by RadioZero,Apr 3 2007, 07:47 PM
how do you measure to know it's still round?
This is a first time thing for me and I did it for a friend at work that is a bit short on funds. I was careful not to heat it to long and I ground the weld smooth on the inside of the rim and bead area. The wheel looks like a tire should mount fine and hold air. I think the rim had a bit of a bend to it before I did anything but, not to bad. After we mount up a tire and spin it on a balancer we will know how good or bad it is. I am hopping it will come out ok
Originally Posted by Bandiscoot,Apr 3 2007, 08:49 PM
probably put it on a wheel balancer ... that could tell you pretty well i think (besides just being balanced of course haha)
Please stand by
Tight work PUDDY
believe it or not you just did your first professional wheel repair job. Wheel repair is just like body work the only difference is you're working with aluminum. Just sand it smooth, spray the color, mount the tires, balance and you just saved a lot of money without switching to Geico. Now are you ready to do mine?
Originally Posted by jcarlton,Apr 4 2007, 08:31 AM
If it is just a crak that is not hard to weld. If it is out of round, good luck with that.
Did you do the welding? If so you can play with my tig welder when you want.
With as bad as my eyesight is and is getting I may not be able to ever do any precision welding
