Removing Dashboard
Hi
I need some help. I want to remove my dashboard. Some of the bulbs behind it went out near the AC panel.
Has anybody done this before ? Any diagrams or pictures you guys might have would be great.
Thanks,
Omar
Thanks,
Omar
You have to pull the trim ring around the speedometer and lower the steering column to access it. This is a common problem. There are links to this. I'm on my phone so can't search it right now
loosen 4 bolts under the steering column (you can probably remove the 2 rear ones, but loosen the 2 front ones), then 2 screws on the dash drip under clip/flaps above the instruments.
Trim ring comes right out, then you can pull out the AC controls and start doing bulbs on that.
