Gateway S2000 Owners Members for St. Louis MO and area.
3rd gear grind
Old Jul 18, 2011 | 09:11 AM
triforresttri's Avatar
Default 3rd gear grind
Third gear is grinding when I shift from 2nd to 3rd. It only happens when I'm accelerating pretty hard. I've changed out the transmission fluid twice now; once w Mobile1 synthetic and once with Honda MTF. I'm thinking it's a syncro or something but really not sure. Any ideas on what it might be or suggestions for a reputable shop?
Old Jul 18, 2011 | 11:31 AM
8BALL's Avatar
If the fluid changes did not lessen the problem, it most likely will be the synchro. It's really hard to tell without listening. Does it slip too, or just grind?
Old Jul 18, 2011 | 08:13 PM
No slipping at all. It just grinds when going from 2nd into 3rd.
Old Jul 19, 2011 | 01:36 PM
8BALL's Avatar
Based on your desciption, the 3rd gear synchro is bad. About $1500-$2K to fix. If you want to read more, Go to "Under the Hood" and key in "2nd to 3rd gear grind" in the search engine.
Old Jul 19, 2011 | 02:25 PM
Holy $%*#!!! Did some reading and I just might see if i can find someone parting out a transmission.
hypforlife32
Aug 19, 2010 05:45 PM
Atb117
May 5, 2009 02:43 PM
jvaj_ap1
Apr 16, 2008 06:10 PM
johnnyb
Jul 19, 2007 05:07 AM
ButtonBoy
Nov 3, 2003 06:40 AM
