3rd gear
Old Apr 12, 2008 | 05:40 PM
jvaj_ap1's Avatar
Default 3rd gear
hey i got a question about my s2k 3rd gear, whenever i do high rev on 2nd gear and switch to 3rd, the gear grinds, also when i down shift to 3rd it grinds? i was wondering if this is normal? anyone help?
Old Apr 12, 2008 | 05:46 PM
ian05s2k's Avatar
is it grinding, ir is it rough going into gear? Mine was a little rough going into gear, and i changed my tranny fluid and it fixed it right up. It is pretty cheep if you do it yourself and probally not a bad thing if you havent done it in a while.
-Ian
Old Apr 12, 2008 | 05:51 PM
jvaj_ap1's Avatar
uh.. its not grinding that bad, it grinds, but it still goes in gear. but thanks for the info, i'll do that and see if the problem still continues
Old Apr 12, 2008 | 07:56 PM
pitstops's Avatar
grinding on down shift is the first sign of your synchros going bad.
Old Apr 12, 2008 | 09:07 PM
Carbon Blue's Avatar
change your tranny fluid out first and see if that helps any.
Old Apr 13, 2008 | 08:27 AM
SisleyHonda's Avatar
a good trick with hondas are to change tranny fluid every 10k, recommended by some of the top honda mechanics i work for, it good for long life
Old Apr 13, 2008 | 08:34 AM
preludepatrick's Avatar
3rd gear is notchy on every s2000, however, grinding is not normal. While tranny fluid replacement may temporarily alleviate the problem, this is ALWAYS a mechanical issue (synchro) that needs to be addressed.
icemans2k02's Avatar
yea sounds like synchro, but i would try the cheap alternative and change the fluid
Old Apr 15, 2008 | 10:20 AM
sbrodacz's Avatar
Banned
Doesn't a syncro usually start with 2nd gear if it goes bad? The easiest and cheapest thing to do is change the fluid. If it's still grinding... Take it in. Pray its not a syncro.
Old Apr 16, 2008 | 06:10 PM
jvaj_ap1's Avatar
any idea how much it will cost fix the syncro?
lunardeathgod
Jun 19, 2012 03:47 AM
hypforlife32
Aug 19, 2010 05:45 PM
tronvex
Nov 10, 2008 07:39 PM
TLS-S2K
Sep 3, 2008 10:13 PM
559s2k
Jul 7, 2006 04:33 AM
