Gateway S2000 Owners Members for St. Louis MO and area.
Automatic Transmissions
Old Sep 16, 2010 | 10:08 PM
Diz's Avatar
Diz
Default Automatic Transmissions
Hola everyone!
I know I got everyone's attention since the S doesn't come with one of these. My question is this, I have heard from several people that if you change the tranny fluid in a car with an automatic tranny that it messes it up and will soon after drop the transmission like a bad habit. The last couple days when the Camry is cold the transmission will slip between gears 1 and 2. Would it hurt to change the fluid and see what happens? I personally think it may benefit but in the past have been told otherwise. Thoughts?
Old Sep 17, 2010 | 01:21 AM
Keith's Avatar
Wouldn't hurt at all to do a tranny fluid change... it's the cheapest place to start.
Old Sep 17, 2010 | 06:11 AM
8BALL's Avatar
Absolutley!
Old Sep 17, 2010 | 09:09 AM
Hondassport's Avatar
Originally Posted by 8BALL,Sep 17 2010, 08:11 AM
Absolutley!
I agree, change it. The tranny probably holds 9-10QTs and you will only get 3-4 when you drain it, so refill the first drain, start the engine run tranny thru gears stop engine and drain again, repeat.
Did you check the oil level cold??? It just might be low.
Old Sep 17, 2010 | 07:10 PM
SmagsS2k's Avatar
You could always run it by AAMCO, they can do a tranny flush that could help this but I'm not a tranny expert
Old Sep 18, 2010 | 08:34 AM
jimmij's Avatar
I hav always change my automatic transmission fluid at 75,000 miles. I have never had any issues. The Envoy went over 300,000 miles with no issues on regular changes
Old Sep 20, 2010 | 08:59 PM
Diz's Avatar
Diz
I checked the fluid and the level was fine. I think I may attempt this fluid change and see what happens. I need to change the oil as well sometime this week. Thank you for the responses!
nin10dough
Jun 18, 2010 05:02 AM
hyperkin
Feb 1, 2010 09:46 AM
p0pe
Jun 11, 2006 04:25 PM
allenheathdj
Apr 29, 2004 06:44 PM
tesseract
Mar 27, 2004 02:37 PM
