Gateway S2000 Owners Members for St. Louis MO and area.
Dude, gross.
Old Aug 7, 2007 | 02:50 PM
SlipAngle79's Avatar
Default Dude, gross.
I lent the 92 Camry to a friend for a while and just got it back last weekend. While they had it, they reported standing water on the floor, maybe 1" or so. It had rained, so I figured there might be something leaking but once I got it back, everything checked out - sealwise. I figured I would let it dry, but today I noticed more water on the floor. After a browse through the Hanes manual, I started pulling up the carpet to see were the water came from. this is what I found:
Here it is. WHen I pulled this little rubber hose out, all hell broke lose - it had been clogged and the water that had accumulated ofr a month started showeringout all over the place.
Shop vac filled with brown water form interior and AC:
Just thought I would share for anyone who might have water on there floor for no apearant reason. I am letting it air dry in the sun. It was starting to smell bad and give me a headache
Old Aug 7, 2007 | 03:36 PM
JulieU's Avatar
Administrator
Funny... similar thing happened to my Integra last month... not quite as much water tho. It wasn't a clogged hose either. It ended up being some metal piece (some sort of rain guard maybe? ) under the trim by the windshield that was bent too far forward. Just bent it back and no probrems since. But the water in the shop vac looked very similar. Nastiness.
Old Aug 7, 2007 | 03:47 PM
SHADE2000's Avatar
little advice if you want.that material on the back of factory carpet.you can replace your self if you want.you can buy it at any LOWES or HOME DEPOT.The material is very close to what s on the factory carpet.what youll need is a sharp razor blade,the backing material,one can of 3m spray adheasive(the good stuff).of course steam clean the carpet when done.
Old Aug 7, 2007 | 07:46 PM
rehile's Avatar
eww!
where does the hose drain from? by the sound of the water depth, there must a be a huge funnel/reservoir at the top of the hose -- ??
Old Aug 8, 2007 | 07:55 AM
It was draining form the AC - you know how water drops out while the AC is on. I think it is also connected to the heater core. Thanks for the tips, I think I will leave the insulation in for now, how would I go about steam cleaning the carpets though? It doesnt smell bad in the car anymore, but when I turn the AC on, I think I smell some mildew. How would I get rid of that?
Old Aug 8, 2007 | 08:14 AM
Doug1627's Avatar
[QUOTE=SlipAngle79,Aug 8 2007, 10:55 AM] It was draining form the AC - you know how water drops out while the AC is on.
Old Aug 10, 2007 | 05:02 AM
^ is nice, I like. I think I will have to buy some if this stuff - thanks for the linky. Does anyone know were to get the carpets stream cleaned? Detial shops?
Old Aug 10, 2007 | 05:33 AM
Doug1627's Avatar
I would rent a steam vac or even buy one before paying someone. I think they overcharge by ALOT at the detail shops. Just my 2 cents.
gwsinclair
Jan 18, 2014 04:40 AM
RobEvans
May 21, 2012 12:15 PM
veehexx
Nov 3, 2011 12:33 PM
Fob
Sep 16, 2004 10:34 AM
JonasM
May 25, 2004 09:24 AM
