First Install-Fluid Day
Originally Posted by rpstl,Feb 19 2006, 06:41 PM
I'll have to check that out....feeding off the interior light (assuming my car isn't in the shop during the install day). I ran mine from the fuse box on the drivers side foot panel and up the pillar cover.
and that is were you should run it from. Best option IMO
Originally Posted by 8BALL,Feb 19 2006, 05:15 PM
and that is were you should run it from. Best option IMO1. replace clutch slave cylinder.....looks easy
2. install hardtop strikers
3. Oil change......maybe
Hopefully I'll be able to make it.
Originally Posted by rpstl,Feb 19 2006, 07:36 PM
From the host.....don't forget to bring 4 or 5 quart capacity containers for the oil and other fluids, I only have 1 or so laying around that would work for the fluid. When buying the oil, buy the 5 quart container so we can reuse it with the drained fluids. Thanks.
Originally Posted by SpoonS2kMe,Feb 25 2006, 06:47 AM
i'd like some help installing the hondata img was gonna do it at my house but figured that i could use the extra hand...
Trying to build a list of attendees and work that needs to be done to get a better feeling on times. Would love to have some extra time at the end of the day to go for a cruise. To date we have the following:
8Ball: Grease CV boots, possible brake fluid bleed
folex187: tranny fluid with GM Syncromesh
jimmij: hard wire V1
Kschmied : Brake Fluid, Tranny Fluid, Rear Diff
4wheelVFR: replace clutch slave cylinder, install hardtop strikers, Oil change
SpoonS2kMe: hondata img
Any one else... How about the host (rpstl)? rehile? hondassport?
