Gateway S2000 Owners Members for St. Louis MO and area.
Powdercoating
Old Nov 19, 2007 | 01:32 PM
Doug1627's Avatar
Default Powdercoating
Found this scrolling the forums. The guy who posted it was a first time user and gave good results. Said its easy to operate and produced good looking results.
http://www.caswellplating.com/powder/powder_coat.htm
Edit January 15th, 2008
Finally got around to some powder coating. This was a very simple process. I lightly sanded the metal that my brother Kevin and I were powder coating, I used 400 grit sandpaper. From there I powdered them using 20PSI from the compressor and 2 inches of powder in the powder container. Once powdered the parts went into the oven at 400 degrees for 15-20min. Curing time depends on the paint you are using. We powdered my J's License plate holder and a boost valve for his Miata. Both were done in Matte Black. One problem I ran into was orange peel on the license plate holder, I applied the powder to thick. The orange peel is minor and only noticable when looking at the part up close. Boost valve came out almost perfect. Although we had some orange peel I am happy with the results. If you have any questions let me know. When its gets warmer I will take lots of pics and hopefully post an in depth DIY although its pretty self explanatory.
Old Nov 19, 2007 | 01:35 PM
ryanfeldman's Avatar
i use justin with jmb performance. anyone pm me or post for his info. website is jmbperformance.com. awesome work and he has done everything in my engine bay.
Old Nov 19, 2007 | 01:39 PM
Doug1627's Avatar
This is a cheaper method, its also a DIY. for me. But thanks.
Old Nov 19, 2007 | 01:47 PM
my friend and i have actually been looking at our own gun and set up. youtube any diy powder coating videos for set ups and instructions. very informative.
Old Nov 19, 2007 | 01:50 PM
Doug1627's Avatar
I will check into that. I was thinking about doing small things such as the radiator brackets, battery tie down, etc.
Old Nov 19, 2007 | 03:46 PM
8BALL's Avatar
Please post results. If you can make a before, during and after DYI instructions, that would be awesome.
Old Nov 20, 2007 | 05:26 AM
Doug1627's Avatar
I am checking out paint colors. Anyone know if things like Radiator Brackets or intake need High temp paint?
Old Nov 20, 2007 | 05:34 AM
i would think that any powder for powder coating would be high temp since you have to bake the parts at 400+ degrees
Old Nov 20, 2007 | 05:42 AM
Doug1627's Avatar
Good point. The sites I have been checking have "normal" and they also have paints that are high temp. They advertise high temp on things like headers and exhaust.
Old Nov 20, 2007 | 05:53 AM
Doug1627's Avatar
I had a change of mind. I will be buying this in the next few days. DIY will be posted as well. http://www.harborfreight.com/cpi/ctaf/disp...temnumber=94244
