Gateway S2000 Owners Members for St. Louis MO and area.
Top Repair
Old Apr 6, 2010 | 07:47 PM
ryanfeldman's Avatar
duck tape is the way to go. mine ripped in the normal spot with the earlier yrs and with some dry rott, there is a nice hole. couple of strips of tape does the trick
Old Apr 6, 2010 | 09:26 PM
Sixth.Gear's Avatar
Originally Posted by tudernos,Apr 6 2010, 08:08 PM
If the price is right you can buy mines!
Two dolla! Two dolla!
Haha just kidding. I'm rocking the duct tape for now and I'll try the method linked by ryanfeldman... seems cheap and fairly straight forward.
Old Apr 7, 2010 | 06:57 AM
8BALL's Avatar
I've got all of the supplies needed to fix. Want me to bring to detail day?
Old Apr 7, 2010 | 12:31 PM
ro0tbeer's Avatar
ive had 4 tops on my s2k. the last one, i ordered from hardtopguy.com, then my friend whos an ase cert mechanic put it in, in about 1.5 hrs. saved me about 1,000 from the dealer. let me know if you want his info to get it done.
Old Apr 7, 2010 | 01:07 PM
Sixth.Gear's Avatar
That would be awesome, but it turns out I have a field exercise that I CANNOT get out of. I misread the calendar initially thinking they wouldn't have the exercise extend into the weekend but no such luck
Thanks for the offer though!
ro0tbeer- It's such a small tear that i really can't justify replacing the entire top. If I was going to go top replacement route, I'd be getting a hard top. Thanks though!
Old Apr 7, 2010 | 04:55 PM
8BALL's Avatar
We'll do it next time if it's not yet fix - or - feel free to swing by one day/eve, and we can fix it at my house.
Old Apr 9, 2010 | 08:45 PM
SmagsS2k's Avatar
Duct tape on an 07?? Forget that go with the mighty putty. Seriously I would try to mend it from the inside to hold it together and only put a thin binder on the outer seam. I bet someone makes a heat bonded tape that could be activated by an iron. You would want to put a towel between the iron and the vinyl top.
Just my $.02
Old Apr 10, 2010 | 05:34 AM
8BALL's Avatar
You know what.. That's actually a great idea which will probably work. Use a colored sharpie to color it the needed top color ater it dries. Might work better than the vinyl mend I offered up earlier.
Seriously though I'm sure we can fix this up with the products I have on hand for Vinyl repair... I hope you know I was only kidding about the duct tape even though in our group have used that or their temporary repair.
Old Apr 10, 2010 | 11:16 AM
yellows2kguy's Avatar
yeah duct tape actually did work for me for a while! Probably 3-6 months when my tears were really bad before I got my new top. I used duct tape on the inside of the top and I used black cloth tape on the outside and it was okay for a while. Eventually I got a new top - we put it on ourselves - it was an "expletive" but I was only out a couple hundred dollars instead of over a thousand if I had a dealer or shop do it.
Old Apr 16, 2010 | 06:54 AM
Blackedoutinc's Avatar
I used the black gasket maker. It has a littel bit of give, waterproof and matchs the black top pretty nice a layer on the inside and outside has held up very nice.
S2k007
Mar 7, 2010 01:49 AM
The Gent
Apr 24, 2009 09:57 AM
driftintherain
Feb 13, 2008 03:01 PM
nivag
Sep 25, 2006 12:20 PM
Schatten
May 25, 2002 09:36 PM
