Georgia S2000 Owners For owners from Georgia
Need O2 Sensor Help
Old Aug 2, 2012 | 04:39 AM
DJ Maestro's Avatar
Default Need O2 Sensor Help
So a couple days ago I developed a rattle under the car. It sounded like the catalytic converter going out, but I wasn't sure. Before I had a chance to get under the car it throws a CEL code yesterday....P0141...02 Sensor Heater Malfunction. It says the problem is Bank 1 Sensor 2. I called Honda parts to check on the cost of the sensor and they tell me that it is the secondary sensor based on the info given. Honda is asking $300.00 for this sensor! Is there anywhere else that I can get a good sensor for less than $300.00??
Either way I'll be replacing the sensor really soon...just want to know mah options.
Old Aug 2, 2012 | 05:02 AM
El S2000's Avatar
Look up some threads on that rattle... From a lot of them it sounds like the cat filament gets loose and rips through the O2 sensor so don't go replacing a $$ part only for it to get ripped through again. Make sure the cat is ok first
Can't really help you with a cheap place for the part tho
Old Aug 2, 2012 | 05:47 AM
DJ Maestro's Avatar
How do I check to see if the cat filament is loose??
Old Aug 2, 2012 | 09:00 AM
Terrible01's Avatar
Mine was loose and broke the sensor. Chances are, with the car cold and 02 sensor out, you can move it around with your finger... At least I could anyhow..
Old Aug 2, 2012 | 09:07 AM
s2000maniac's Avatar
It's your cat. When we were doing the trans fluid change I noticed that your cat was way hotter than usual after sitting that long. I think the honey comb was loose and was clogging up. That's why we got burned lol!! When the car is completely cold raise it up and tap on the cat and you should hear some metal sound. Or better yet just remove the whole cat and shake it back n forth and you will feel the honey comb moving around. Get a test pipe or Berk HFC. Good luck!
Old Aug 3, 2012 | 08:46 AM
DJ Maestro's Avatar
So in other words, are you telling me that I will need to replace the cat AND the sensor???
Old Aug 3, 2012 | 08:55 AM
only if the sensor has been damaged. if not, you can reuse it. replace the cat. inscase if you have to replace the sensor, you can buy this one http://shop.advanceautoparts.com/web...=oxygen+sensor on checkout use code p20 for 20% off and choose the option to pick it up from store. good luck
Old Aug 3, 2012 | 09:07 AM
DJ Maestro's Avatar
Originally Posted by DJ Maestro' timestamp='1344012412' post='21910942
[quote name='s2000maniac' timestamp='1343927226' post='21908243']
[/quote]
That is for the upstream sensor though. My code is telling me that it is Bank 1 Sensor 2...that is what Honda is telling me is the downstream sensor that is like $300.00. Will this one work in it's place??
Old Aug 3, 2012 | 09:17 AM
No the upstream would be bank 1 sensor 1. Downstream is the one by the cat. The link that I posted will work perfectly fine.
BUT first inspect the cat. The sensors might be fine.
Old Aug 3, 2012 | 09:30 AM
DJ Maestro's Avatar
So now the question is....Berk 63mm or 70mm HFC???
