Georgia S2000 Owners For owners from Georgia
shifting problem
Old Oct 26, 2008 | 05:56 PM
ATL_S2K's Avatar
Arrow shifting problem
Can anybody help me figure out this issue. Each time i shift gear , feels kind of rough getting into gear. And the clutch also feels stiff. I havent had any problem, just today it feels different when i shift. Could it be the Tranmission fluid.? i check it wasnt low. So i dont know if thats the problem or is it something esle.
Old Oct 26, 2008 | 08:16 PM
heavyfoothonda's Avatar
whats up man, well i have heard that the stock trans fluid is not up to the task if u have mods>>? but if you close to stock (ie no forced induction) that its your throwout bearing ...That would make your clutch stiff as well as hard to get into gear>> ap1 ap2? ap1's have that foater that dose not allow the fluid to come back fast enough on hard shifts >>>makes clutch slip>>>got the vortech on mine with an Act puting the power down no prob ne way pm me with more ill help as much as i can > you ever come to savannah ? * Eli*
Old Oct 27, 2008 | 03:20 AM
ATL_S2K's Avatar
i only got a intake and exhaust. other than that its stock.
Old Oct 27, 2008 | 04:36 AM
dan_uk's Avatar
it might need changing if you change the honda MTF and it still feels shit you migth wannt try GM synchromesh
Old Oct 27, 2008 | 11:09 PM
Sup man , thats a great place to start ...The synchromesh is what is in my car>>butter... i hope for ya that this fixes the prob >>still Ap1 or Ap2 ?trans fluid will not afect clutch feel tho>> keep us posted
Old Oct 28, 2008 | 02:27 PM
ATL_S2K's Avatar
i check the fluid its to the max should i just drain it and refill it with the GM synchromesh?
Old Oct 28, 2008 | 02:46 PM
dan_uk's Avatar
not the clutch fluid you need to get under the car and change the transmission fluid
its not too hard here is a good howto:
http://forums.s2kca.com/showthread.php?t=10449
you can get Honda MTF from honda, make sure they give you honda MTF manual transmission fluid not ATF or something else!
if it still sucks try synchromesh, http://www.hardtopguy.com/
Old Oct 28, 2008 | 03:19 PM
ATL_S2K's Avatar
thanks dan uk ill see whats up when i get it check out.
Old Oct 30, 2008 | 08:05 PM
ATL_S2K's Avatar
found out the problem. i found out that i had a new aftermarket clutch. And the last owner that i bought from had some to install the clutch and they did a pretty bad job, so im getting it reinstall. anyone know any good place that would reinstall my clutch for less than 300 Someting?
Old Nov 6, 2008 | 01:45 PM
ATL_S2K's Avatar
ok i figure it out, what was the problem. Went to a close shop near my house just to check out the problem. The aftermarket clutch was install improperly. I just need to get it reinstall. Any one know a body shop that can do it for lower than 300, just curious, if not then imma have to pay 300 something to get my clutch reinstall?
