#@$@#$252rd Official Hard At Work Thread@#$#@$@
Old Dec 2, 2009 | 08:57 AM
AngryTurtle's Avatar
Originally Posted by WhrDLMI,Dec 2 2009, 12:54 PM
What the deuce...
ANywho...
Why?
The sole purpose of the c-clip would be to keep the bolt from dropping down when you pull the cotter pin, right? It doesn't need a machine fit, just enough to hold the bolt. The threads that are on the bolt should be enough to hold the c-clip.
Now... If you were using some sort of pin instead of a bolt, then you could be right. JB Weld is probably the more elegant solution but I worry about it holding up to repeated use.
Id want a pin just for aesthetics. So youd need a slot for the c-clip and a hole for the Pin. Ive got no prob with that set up. Or if it were a bolt and just using the threads.
WhrDLMI's Avatar
Originally Posted by Vadster,Dec 2 2009, 12:56 PM
... as well
Be careful where you ... It attracts flies.
Originally Posted by O-turn,Dec 2 2009, 12:56 PM
Sean is an 8
They are white and i used them 1 time. I gotta make sure the new ones fit first though.
Old Dec 2, 2009 | 08:58 AM
WhrDLMI's Avatar
I figured that was where you were going. I agree. The tricky part will be finding the pins. There is the Intertubes but you will end up buying 1,000 of them just to get one.
Old Dec 2, 2009 | 08:59 AM
O-turn's Avatar
Holla at him on the gchat son. make him offer cannot refuse when new ones come.
WhrDLMI's Avatar
Listening to (bad) songs 30 seconds at a time is giving me a headache.
Old Dec 2, 2009 | 09:00 AM
Its Skip's money. ill take 1000
3AFL S2K's Avatar
Butternut Squash
Old Dec 2, 2009 | 09:01 AM
Vadster's Avatar
top 40 radio?
Will let him know next friday hopefully.
