(-,\\ 198st Official Hard at Werk Thread (-,\\
Originally Posted by bighead,Mar 16 2009, 02:55 PM
replace tires, lower car, revel in a job well done.
pretty simple.
tools:
sockets: 8mm, 10mm, 12mm, 14mm, 17mm
spring compressor
breaker bar/pipe
Front:
loosen lower control arm bolt (17mm)
remove 2 upper control arm bolts (17mm)
remove brake line bolt (12mm)
remove lower control arm bolt (17mm)
remove 2 shock mount bolts (14mm)
Rear:
remove spare tire
remove fuel line from body (8mm, 10mm)
remove shock mount bolts (14mm)
Springs:
attach spring compressor
tighten spring compressor until spring can move freely
remove top bolt (14mm)
remove spring compressor
install new springs (may be able to push down w/o spring compressor)
align shock fork and shock mount holes
install top bolt (14mm)
Front:
Install shock/spring assembly
tighten shock mount bolts (14mm)
install but do not tighten upper and lower control arm bolts (17mm)
tighten brake line bolt (12mm)
jack corner up off jack stand (jack point = knuckle), tighten lower/upper control arm bolts (17mm)
Rear:
install but do not tighten lower control arm bolts (17mm) (use pipe/breaker bar as a lever on upper control arm to align lower control arm bolt)
jack corner up off jack stand (jack point = knuckle), tighten lower control arm bolts (17mm)
install fuel line (8mm, 10mm)
replace spare tire
tools:
spring compressor
breaker bar/pipe
Front:
Rear:
remove spare tire
Springs:
Front:
Rear:
replace spare tire
CTRL+V
Gracias Kind Sir....
Originally Posted by 3AFL S2K,Mar 16 2009, 03:01 PM
yeah, really. People cant resite the national antheme and your remembering all that???
