Brake changing time any recommendations?
Well its about that time and I will be buying brakes and pads online. Can you guys recommend a shop that will change them for me besides the dealer. Would do it myself but I do not want to mess with critical parts such as the brakes.
Thanks!
Thanks!
only issue youre going to run into with changing pads is the rear ones...you need a special tool...checkers carries a shitty one so i would recommend getting a good one online or if someone on here has a good one
Originally Posted by JustinsanE,Nov 17 2010, 10:30 PM
are those rotors bigger? if not then why bother?
On my 5 year old RSX Type-S, I still had 90% pad left. I like to use energy management to avoid using so much braking from stop light to stop light...
Originally Posted by IntegraXTR,Nov 17 2010, 10:21 PM
All you'll need is an impact screw driver to undo the screws holding the rotor on...
That's about it for rotors
Thanks for the info!
Originally Posted by DTAG,Nov 28 2010, 01:24 PM
let me know if you never did it yet,,,,i'll do it!!!!!
