SO2 vendors?
I just ordered a set of rears from Costco. When I priced tirerack I think it was about $185 per tire shipping included. Costco should be $175 per tire including mount and balance. Not sure if there is a difference between oem S02 tires and S02 tires from Costco. If you haven't already purchased yours by the time I get mine, I will let you know how it went at Costco.
yea i already took a look at tirerack.com and will probably order from them if i can't get a better deal locally. that costco deal however sounds awesome if those are OEM SO2s. you know when those are coming in? i wanna know how it goes, but i'm gonna need new rears really soon...
There is a huge difference between the OE S-02 and the "normal" S-02. However since the 'normal" tire is not supposed to be sold anymore, you might get lucky and get the correct tire.
The OE tire has narrow grooves and a wider contact patch creating A LOT more grip than the other S-02. The non-OE tire creates a dangerous handling condition because the front to rear ratio is screwed up.
woah thanks for pointing that out Colin. i think i'll play it safe and just order from tirerack.com. anyone know a good cheap place to get these babies mounted and balanced?
shucks i was hoping there was someplace cheaper than eurosport. 20 bux a tire seems pretty expensive to me, but if they got the best machine to do it i guess i have no choice...
I can get it done for free here a Acura, but I still pay to have it done elsewhere cause I don't want the rims scratched! Maybe someone else will chip in on a good place that has the right machines to get it done. What about Revolution?
