Mark this thread as Unsold
Caged 2002 S2000 $25000 OBO Located in Cypress TX
Greetings, Old member with new handle
Caged 2002 S2000 $25000 OBO Located in Cypress TX. Contact via Jeff PM here with your contact info. Question please post to this thread.
Chassis
Honda 2002 S2000 inside and out. No title, it was a savage titled rolling chassis in Suzuka blue when it started it life. It will be delivered with a bill of sale. The shell was completely striped of everything and painted single stage white paint.
6 Point cage built by Lucas Restoration in Houston, TX. It is 1.75 x .120 DOM Steel painted rustoleum flat black.
NASCAR bar for both doors
Door are gutted with crash supports intact w/custom door latch releases.
AP2 Rear sub frame and upper control arms.
CWest exterior mirrors
Wink Mirror for interior rearview. OEM mirror included if needed.
OEM Gutted Hardtop. Most of the interior support structure has been removed to allow the cage to be as far from the driver’s head as it can be. I am 5 11
Izzy’s Cages Front and rear race brackets http://www.izzyscustomcages.com/CustomParts.html
Rennline Front tow hook Rennline Folding Tow Hook-Rennline, Inc.
Rennline fixed tie down point mounted front and rear Rennline Tie Downs (set of 2)-Rennline, Inc.
Aero
APR GTC-200 rear wing with risers
APR front splitter fixed mounted to the front bumper. (The bumper and splitter remove as a single piece)
Suspension
JRZ Single Adjustable 14K/12K Rebuilt in March 2016, Driven once since rebuild.
Buddy Club P1 (Camber and rolling center adjustable)
Instrumentation/Datalogger
Stock Dash removed and replaced with Race Technology Dash2 installed
Race Technology DL1 Club Data Logger DL1 CLUB - Race Technology Ltd - Automotive Technical Excellence
R/T Dash2 hardwired DASH2 - Race Technology Ltd - Automotive Technical Excellence
R/T Steering angle sensor (String Pot) String pot (steering) - Race Technology Ltd - Automotive Technical Excellence
R/T Oil temp sensor Oil / Water temperature - Race Technology Ltd - Automotive Technical Excellence
R/T Oil pressure sensor Oil / fuel pressure Sensor - Race Technology Ltd - Automotive Technical Excellence
R/T Brake Pedal Sensor Pedal position (13mm travel) - Race Technology Ltd - Automotive Technical Excellence
R/T ECU Serial interface Aftermarket interfaces - Race Technology Ltd - Automotive Technical Excellence
R/T Video support license and GoPro Sync cable. GoPro video support - Race Technology Ltd - Automotive Technical Excellence
GoPro Hero 3 White included.
Braking
Wilwood Forged Dynalite 4 piston calipers. With two sets of hats for quick changes. This was a custom made kit and will fit under OEM 16” wheels.
Wilwood rotors https://www.summitracing.com/parts/w...0471/overview/
Carbotech XP12 on all four corners.
Front and Rear 2.5” brake cooling ducts.
SS Lines.
Motor and cooling
F20C OEM with ACL bearings
OEM AP1 Head ported and polished with Supertech valves, dual valve spring and Ti retainers.
CR Racing S2000 Radiator
Mocal 235 Matrix 16 row Oil Cooler BAT, Inc. - MOCAL Oil Coolers
Black XRP AN 10 Fitting with braided lines.
Canton Racing 2Qt Accsump https://www.cantonracingproducts.com...-2QT-NO-VALVE/ w/electric pressure valve
Canton Racing Remote canister oil filter https://www.cantonracingproducts.com...ER-OIL-FILTER/
Canton Racing Oil Cooler thermostat https://www.cantonracingproducts.com...ER-THERMOSTAT/
Comfort and Safety
Cool Shirt Club-12 mounted in the trunk with switch and LED on dash. https://www.pegasusautoracing.com/pr...asp?RecID=5455
Sparco R 345 Steering Wheel Sparco USA
Rennline Steering wheel Q/R Rennline Steering Wheel Quick Disconnect Rev B-Rennline, Inc.
Driver Seat Sparco ERGO M Black (Vaild Cert) Sparco USA
Passenger Seat Sparco Evo II US Black (Old Cert, New Cover) Sparco USA
Driver’s Belts Black Schroth Profi II-6H (Vaild Cert) https://www.schrothracing.com/products/profi-ii#1602
Passenger Belts Black Schroth Hybrid II (Old Cert) https://www.schrothracing.com/products/hybrid-ii#1591
Both seats a fixed mounted on custom brackets. New owner may need to have these rebuilt if he does not like the location of the set. The passenger seat is mounted as far back as it can be. It is tight for me to fit.
Firebottle Fire Suppression System. Auto nozzle 175 degrees fuel tank and interior compartment, manual pull for engine and passenger compartment AMRC-1000 – Firebottle Racing
Schroth Driver’s Window net https://www.schrothracing.com/produc...cage-nets#1618
Schroth right side net. https://www.schrothracing.com/produc...cage-nets#2605
Master Kill Switch https://www.pegasusautoracing.com/pr...asp?RecID=1465
Driveline
Transmission AP1, 5/6 Syncros replaces last year. AP2 output flange
ATC Prolite Flywheel 600350 // Advanced Clutch Technology
OEM Clutch
ATC HD pressure Plate H021 // Advanced Clutch Technology
AP2 propeller shaft
Comptech reinforced AP2 diff housing, Carbonetic 1.5 Way LSD w/AP2 input flange
SS clutch line
Exhaust
Rick’s Header
70mm Test pipe.
Magnaflow Full Ti exhaust. This has been professionally re-welded a few times over the years. The B-pipe baffle had broken loose before it was purchased by me. Weight 6 lbs
Dei Heat wrap from Header though B-Pipe
Trailer $8500 OBO (To be sold with car, or after car is sold)
24” Vintage Trailer Bandit http://www.vintagetrailers.com
Manufactured 2006
All new tires (installed in June)
Air hose on reel
EZ-Track on both walls
3 Jug holder with 3 Scribner clear jugs
Folding tire rack Hold 4 S2000 tires and a spare
Trailer Aid in holder
Floor Jack Holder
EZ Load leveling hitch
Sway control
The trailer interior was completely refurbished in 2014-15.
Rear View
Passenger Side View
Dash View
Front Brakes
Under Dash
Dash View with Steering Wheel
Passenger Seat
Engine Bay
Fire Suppression
Driver Seat
Chassis
Aero
Suspension
Braking
SS Lines.
Motor and cooling
Comfort and Safety
Driveline
OEM Clutch
AP2 propeller shaft
SS clutch line
Exhaust
Rick’s Header
70mm Test pipe.
Manufactured 2006
Air hose on reel
Floor Jack Holder
Sway control
- All new ¾” plywood flooring
- New Black Coin Commercial grade flooring G-Floor 10 ft. x 24 ft. Coin Commercial Grade Midnight Black Garage Floor Cover and Protector-GF75CN1024MB - The Home Depot
- Custom base cabinets and generator box with stainless steel counter top. 5 drawer Craftsman tool box built in.
- 120 Volt plugs and light switch
- Two 4” LED Shop lights 120
- Custom LED lights down both sides of the trailer (12V)
- New 8K tie down anchors
- Husky 4500 LBS Elective Trailer Jack https://www.etrailer.com/Trailer-Jac...y/HT87247.html
- Deep cycle battery to run 12V lights
- Atwood Air Command RV AC 15K
Rear View
Passenger Side View
Dash View
Front Brakes
Under Dash
Passenger Seat
Engine Bay
Fire Suppression
Driver Seat
Stratocaster
R&C Parts For Sale
10-09-2017 03:15 PM
