I need help wiring foglight kit for my S2000
Old Mar 23, 2002 | 01:54 PM
High Revs's Avatar
Default I need help wiring foglight kit for my S2000
Hi everyone, I'm new to the forums but I need your expertise. I've had my S2000 for a couple of years now and decided to do my first mod. After searching the threads on foglights I found alot of interest and talk, but could'nt find where too many people had actually done this. Last weekend I installed the kit from the Honda Odessy and it fits. All I had to do was shave a little on the black trim to make it fit better.
The problem is that the connectors for the harness under the dash are different. The Odessy connector has a 14 pin and the S2000 is a 16 pin. The plug for the fuse box also looks different. I don't want to ruin anything so I need someone that is experienced with this. Thanks The kit only costs 199.50 through handa-accessories so its not to bad of an investment. You can also download the instructions to see what's involved, but it was'nt that hard. Thanks again for any advice.
Old Mar 25, 2002 | 09:50 PM
S2WOOOW's Avatar
What kind of switch are you using? Was it part of the kit, and does it fit into one of the blanks on the dash? Was there a relay as part of the kit? I'm not sure why there are so many pins. I hooked up driving lights. I mounted the relay in the engine compartment. Then ran 2 wires into the dash for the switch. I just used a radio shack switch.
ConnieS2k
Jan 16, 2012 03:28 AM
rk604
Nov 4, 2010 06:00 PM
lookuphere
Sep 10, 2008 09:52 PM
RevRanger
Dec 24, 2007 02:20 AM
High Revs
Mar 23, 2002 03:17 PM
