bucking throttle response
Old May 24, 2001 | 07:32 AM
heli's Avatar
I am getting a 'bucking' throttle response sometimes in first or even second gear, usually when accelerating from low speed. It has happened occasionally on gentle hills as well as on the flat. If I either back off or floor it then it goes all right but this is not always good to do when in traffic.
It seems that this is a dynamic oscillation of my foot on the pedal, coupled with some looseness in the driveline. In my civic, I can get a similar effect if I let got the seat ratchet while acceleration. Please don
Old May 24, 2001 | 07:44 AM
lvs2k's Avatar
Depress clutch, let off gas; release clutch while simultaneously applying power. Repeat, if necessary. It happens to me sometimes after going over those damn speed-bumps in parking lots or child-filled streets.
Old May 24, 2001 | 07:48 AM
GT2000's Avatar
Happens to me more when the engine is colder.
Can drive you a bit nuts and makes you look a bit amateurish! Just do as lvs2k said and that'll fix it.
Old May 24, 2001 | 08:54 AM
S2000 Owner's Avatar
Believe it or not --- put your foot to the floor! This will stop it.
There is an old thread about this --- it's like the old Offy Indy cars, they used to do the same thing. Too low an rpm for the gear.
Old May 25, 2001 | 01:38 AM
Ross's Avatar
There is another thread talking about this, particularly when in traffic in higher temps. Its beleived to be the IAT sensor (Intake Air Temp) if you search you may find the thread talking about getting this replaced.
Old May 25, 2001 | 01:57 AM
rstark's Avatar
I think this is normal on a manual transmission. I had it in my '88 Integra, and also on a '71 VW Squareback. Happens at very low rpm, not all the time though, just push in the clutch.
Old May 25, 2001 | 03:09 AM
Munch's Avatar
Most manuall transmission cars will do this at a very low rpm, it is a function of available tourque (remember we don't have much at high RPM's - never mind at 1200 to 1500) and throttle position.
Old May 25, 2001 | 07:43 AM
REV2RED's Avatar
happens once in a blue moon to me and it is quite annoying. i feel as if i am doing nothing wrong and it just starts jolting on its own. its like im at the rodeo. i guess its normal if others experience it as well.
fastnfurious14
Oct 9, 2013 06:08 PM
Dragon Curve
Jan 21, 2005 07:02 AM
supernig
Feb 18, 2002 04:03 PM
mingster
Mar 10, 2001 05:47 PM
