Injen Install
Old Jul 10, 2002 | 09:00 PM
dp2580's Avatar
Default Injen Install
Need some tips on installing my injen CAI .. in my 2002 s2k.. I was wondering wut kind of tools I needed in completing this job? and if I can get some pictures... on where I have too cut....?? .. hope you guys can help me out... this my first time changing a CAI in my own car... thanks..!
Old Jul 11, 2002 | 04:59 AM
9906's Avatar
dp2580,
I just used a sharp knife to cut the plastic. It's not too difficult to eyeball where you need to cut -- it's on the leading edge at about 2 o'clock once you loosen and peel back the wheel well liner. The picture in the install directions is pretty accurate. I didn't take off the front bumper; just jack up the passenger front side good and high, remove the fasteners in the wheel well and peel it backwards. Slide underneath and remove the fasteners and then the flat plastic belly pan. Then you can see where the intake will need to run up and into the engine bay. To help visualize it, have someone hold the intake in the orientation it will be installed, but to the front of the car. You'll see where it has to go. Remove your stock airbox and vacuum plumbing and either take a picture or draw where the vacuum lines go as it's easy to get them confused after the Injen is in place. Stuff a clean rag or plastic bag in the throttle body to avoid any FOD in there. Once you've made your cuts, stick the TB end of the Injen in through the wheel well and up into the engine bay. It's a lot easier to have someone else help you with this, as it requires some twisting (not bending!) to get it into place. As the install flyer says, leave the plastic sleeve on until you have it in place, as it scratches very easily.
Afterwards, I took a dremel and cut out the plastic intake plate in the bumper to open up a bit more air, but this is optional. Good luck, have fun.
Old Jul 11, 2002 | 07:42 AM
iLikeBeer's Avatar
Wow, thanks 9906!
Old Jul 11, 2002 | 09:43 AM
wake88's Avatar
Do a search and you'll find some threads on the install. There's a few good posts that really helped me out when I did mine.
Good luck and most importantly, enjoy. The sound is amazing!
Steve
Old Jul 11, 2002 | 11:49 AM
dp2580's Avatar
thanks 9906... always been helpfull..
so how did it go... with the mugen ECU.. did it help out in the long run... was it the missing piece...?? Does the Mugen ECU make that much of a difference.... Just wanted to know if it was worth.. it... I'm actually thinkin about gettin the ECU too.... 1500 is a lot of money.. and I'd like too see some gains.. big ones I hope..........=) Thanks for your help again...
Old Jul 11, 2002 | 04:18 PM
9906's Avatar
[QUOTE]Originally posted by dp2580
[B]thanks 9906... always been helpfull..
musicfreakjohn
Oct 3, 2008 05:17 AM
Auditdude
Jun 19, 2007 12:47 AM
E_ME_22
Sep 17, 2004 07:32 AM
E_ME_22
Sep 11, 2004 08:18 PM
nHobbes
Jun 3, 2002 05:30 PM
