Finally!! Got my sound system installed!
Old Oct 5, 2001 | 02:32 PM
F1 Tech's Avatar
Default Finally!! Got my sound system installed!
I finally got my system installed after all the questions and indecisiveness. I've got the JVC MP3 player hooked up with the PAC remote. It works wonderfully! Sony 1621s are in the front doors. I decided to use my Dremel I had from college to cut out the rear panels to install the 4" Polks Lucid style. I used a hard cardboard as a template before making the final cut. It took about 3 hours to do. I've got a Sony Xplod sub sitting in a Q Logic truck box. The box fits awesome in the well. It's nice and tight and is very secure without bolts and screws. The Kenwood 800 watt 5 channel amp is hooked up to all the speakers behind the seat. A Rockford Fosgate Capacitor helps with the power. Overall, I am very happy with the way it sounds. The amplified rear speakers sound great and are highly recommended. I plan on switching out the Sony 6.5s for something better later, perhaps the Polk 6.5. I would like to thank everyone for helping out with all my questions and comments. Now I can hear my music!!
Old Oct 5, 2001 | 02:40 PM
legendr34's Avatar
thats a very nice setup, I very much like the Headunit, I was considering it, but I wanted the dash controls to work...how does PAC work exactly if you don't mind me askin
Old Oct 5, 2001 | 03:44 PM
Pinky's Avatar
Where did the PAC eye dissapear to?
It actually works by taking the IR transmission from your remote and then re-sending that same signal out via a wired remote. It is hooked up to the dash controls and each button is bound to a button on your remote. After programming toss the remote in your glove box and use the dash controls.
Old Oct 5, 2001 | 05:59 PM
F1 Tech's Avatar
The eye is placed just underneath the head unit's sensor which is on the bottom right corner.
Old Oct 5, 2001 | 06:40 PM
S2R's Avatar
S2R
Looks great. I like where you mounted the amp.
Old Oct 5, 2001 | 09:15 PM
S4 Mike's Avatar
What's the part/model # of the q-logic box? I'm trying to decide between that or a custom made enclosure. How's the bass with this system?
Old Oct 5, 2001 | 10:11 PM
lucid's Avatar
Thats a sweet setup man!
The Q-logic's are nobrainers and inexpensive, unless you're a die-hard use them!
Old Oct 6, 2001 | 12:16 PM
F1 Tech's Avatar
For anyone who is interested in the box. This is it.
http://www.crutchfield.com/cgi-bin/S-QGp0V...44T6510SX&o=&a=
Old Oct 7, 2001 | 09:50 PM
DouglaS2000's Avatar
Sweet, I have it setup the same way. Except the box is facing the other direction in mine. So do you notice any difference with how it sounds as far as the direction of the box goes?
Old Oct 8, 2001 | 09:49 AM
B.C.'s Avatar
Did you place the Sub on top of the the jacks and particle board or did you take off the jacks on the bottom and it's casing?
BC
